93nav
- August 25, 2004
- Minneapolis, MN
- 2002 Sport
2004-08-26
The radio in my 1993 Mazda Navajo has quite working entirely. I can press any of the buttons and nothing happens. I have checked the fuses and they are all ok. All other displays, lights, etc on the vehicle work, with the possible exception of the right speakers, which have never worked. When I pull on the headlights, the buttons etc on the radio do light up. The radio is original with cassette. I think that it is the mid level radio. For about one or two months before this happend, when I pushed the 'clock' button on the radio while the ignition was off, the time did not always display correctly, usually it was garbage, not even recognizable characters.
I pulled the radio out and could see nothing wrong with the conectors. I bought a replacement (exact same model near as I can tell) on e-bay that was supposed to have been bench tested. That one does not work either, though when I first plug it in, and before I turn on the ignition, I can press the 'clock' button ONE time and get '12:00' to display. This only occurs the first time that I press the clock button, after that nothing. I can unplug it and replug it in again and get the 12:00 one time agaion. This does not occur with my original radio.
I used my multimeter to try to test the connectors (I am new to this, so results are not guarantteed). No matter what the position of the ignition switch, I always got 12.0v +/- on the 'memory feed' line (light green and yellow). With the ignition turned on, I got 11.84v on the 'Radio power feed' line (yellow and black). Pulling on the headlighs, I got 10.16v on the 'panel illumination' line (light blue and red), plus the other two results. There are three connectors going into the radio, a round single 'plug' type one, a long rectangular one with places for 8 wires, but only 6 were used (this is the one I checked), and a square one (speakers???).
I have not looked at the amp at all (I think I know where it is, but....)
I would appreciate any help with this if possible. Or if it turns one I got a bad one from e-bay, I am interested in a replacement.
Thanks!!!
Thanks!!!
