1993 stalling again ???? | Ford Explorer Forums - Serious Explorations
mjatondo
tulare ca
1993 xlt 4x4
i spoke too soon read below for the story ...my 93 explorer stalled again ...
about a moth ago my 1993 ford explorer xlt .4.0 6 cyl suv started making a a popping sound under the hood .like a muffled backfire.i put in a bottle of lucas problem was gone .a week later same thing again with idle low.so i changed spark plugs and fuel filter .problem stopped .for a few days.began to get progressively worse .no check engine light .began fuel odor and very bad gas mileage .i replaced the iac valve (new) started running perfect for about 10 minutes.all in all ive tested maf sensor ,tps, and looked for leaks.i haven't ran it on the computer tester because no check engine light.one thing i can add my temp on dash doesn't seem to be working right never goes above the first line .also my heater barely gives off heat.at present the car stars but wont run unless i pres down on the gas.and stalls most of the time i let it off ...someone help please
then....
Smile Second update
Purring like a kitten ... No black smoke ...so sputter... No stall..
For now .
Test drove it around town let it idle etc.rpm stable ..
So looks like for me ...
Replaced fuel filter
spark plugs
added lucas fuel injector cleaner
cleaned mass air flow sensor with (maf)approved cleaner
cleaned idle air control - replaced (didn't work)
bought a voltmeter tested all sensors ohms and voltage.
Purchased (iac) new ...two year warranty ... At auto zone 65.00
reset computer and bingo problem fixed
