formeat
- April 16, 2013
- Tempe, Arizona
- 94 Aero XL 3.0 2WD Shorty
A couple of vacuum line questions on a 1994 Aerostar 3.0L 2WD. I’ve searched with no luck.
There is a long vacuum hose that runs from the Purge Canister (located under the air cleaner) up to the INLET side of the Purge Canister Solenoid (located to the right of the manifold up on the driver’s side). Anyone know where on the manifold the vacuum line from the OUTLET side of that Purge Canister Solenoid connects to?
Also, there’s a really narrow piece of pre-formed white plastic tubing that bends at all kinds of angles that connects on one side to the middle of a round silver thing on the passenger side of the engine. It kind of looks like the fuel pressure regulator or EGR valve, but it can’t be either as it has no other outlets. Anyone know what that silver thing is called and where the other side of the pre-formed tubing goes?
Thanks!
Thanks!
