1994 Coil Pack | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
1994 Coil Pack
shrkfan00
I have a 94 with 80,000 miles on it. My question is when should the coil pack be replaced? I changed the plugs and wires, but there is still just a very slight hesitation and it lugs a little at low rpms. Overall it runs very well. Gets about 24 mpg on thr freeway.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
marragtop
balt, md
91, 92, 95, and 2000 xlts
Have you pulled the codes? There may be a code stored even if the CEL is off.
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
There isn't really a set time to replace the coil pack.. Most run it until it starts to have issues.. many are still running the factory coil pack well past 200k miles.
Ours has 375k miles on it..
~Mark
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
What kind of code reader did you buy? Did you replace the fuel filter? It could cause hesitation. Add some fuel injection cleaner to the gas tank after you replace the filter. Sometimes bad gas could cause similar problems.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
shrkfan00
That's the tester that I bought. I followed the instructions, but it does not work. When I turn it on the relays under the hood start clicking and then nothing, no read out.
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
So it sounds like it's entering the test mode, but the reader isn't getting any output. Does the CEL flash? In test mode, the codes can also be read by counting the flashes of the CEL. If the CEL is flashing, then the reader just isn't seeing anything, and you can bypass the reader. If the CEL isn't flashing, then there is a loose connection somewhere that is causing the computer to fall out of test mode.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
