disvnvet
- November 18, 2009
- Sacramento, California
I recently changed the transmission on my 1994 Exploder 4X4 (A4LD).
I did the KOEO and KOER tests and the only code I got was 176 i.e. Left O2 Sensor Lean. There also appears to be a transient code 543 for PCM but only appears when I get a false start i.e. has to attempt start twice.
I note that only because I don't know if it is related to the problem I am having.
Problem:
When cold, the vehicle builds adequate RPM however, the tranny does not respond equally. It kind of lags.
After the vehicle is warm you feel a transition and the tranmission responds normally.
While driving from that point on, everything operates normally.
After I shut down and park for 20 or more minutes, the same situation arises.
My thoughts:
Since I don't know enough about the transmission, I am thinking, and it has been suggested, that it may be the vacuum modulator or the governor.
I was referred to this site and it was recommended that I search on Modulator and Governor which I have done.
Normally I wouldn't hesitate to do either however, some of the horror stories about losing the pin, no pin installed, not being able to get another pin for the modulator etc, worry me.
Regarding governor I am lost. I know where it is and recognize that the transfer case etc. need to be pulled.
It would be nice also if someone has a picture showing the modulator and the pin and the same applies to the governor. With all the knowledge I have seen so far on the forum, they probably are already posted but I have been unable to find them. Maybe you can just point me in the right direction.
Questions:
1. If the vacuum modulator is bad I already know that it will cause the problem however, other than finding fluid in the line is there any other troubleshooting method? Also, when looking for fluid in line should it be done prior to starting or after warm. I am not sure what the modulator does and have not had any smoke from fluid being sucked into manifold. I pulled the line at the manifold and there is no apparent fluid inside however, have not looked at the lower end yet.
2. If it is the governor, will the tranny need to be drained first. Also, what will I be looking for. The tranny was recently rebuilt before I got it. After reading a few articles, and forums, I don't want to teardown until I fully understand what to look.
I have a couple of other questions regarding fuel filter removal and alignment but will post them after the tranny issue is clarified.
Thanks in advance
Problem:
My thoughts:
Questions:
Thanks in advance
