9194 Sportman
- April 14, 2009
- Nova Scotia, Canada
- 1994 Explorer Sport
Hello friends,
I have a totally bone stock 1994 Explorer Sport 2WD.
It has the 4.0 liter V6, 5-speed trans, 8.8 Diff with 3.27:1 open diff, A/C, Power Windows, Power Door Locks, Power Front Seats, Cruise, Map Lights & factory Stereo system.
I installed a factory Frame Hitch to tow my utility trailer.
So, The factory original 95-amp 3G alternator finally failed and I want to upgrade to the 130-amp 3G optional alternator.
I acquired an 3G 130-amp alternator and when I compared both alternators side-by-side I noticed a couple differences: FIRSTLY, the 130-amp alternator has a larger diameter round body which I knew it was supposed to be, but, SECONDLY, I noticed that the 130-amp alternator has a larger pulley diameter(???).
To clarify, the 95-amp 3G alternator pulley has 2-3/4" diameter, whereas, the 130-amp 3G alternator has a 2-3/8" diameter pulley.
My question is whether I swap pulleys or leave the pulleys alone? There must be a reason for the smaller diameter pulley on the 130-amp alternator(???)
Can anyone explain why there are different diameter alternator pulley AND, which pulley size should I use with the 130-amp alternator on my 1994 Bone Stock Explorer Sport?
Many thanks in advance - Pete
