check your switch you will need to take it out and take your wires loose and touch the wires together, if this does not work check your fuse in the fuse box,
If the fuse is good check the connection to the lights. also check and make sure they are grounded really good,,,If the ground is not leading back to the battery ,,try grounding to the bumper because this is an excelant ground.....
