I have a 1994 Mazda Navajo with 175,000 miles. The car has been running flawlessly until tonight (45 degrees out in case temp plays an issue). During my drive home at stop lights the car would idle for 30 seconds and then begin to make a chugging noise that will get progressively louder and then make the car shake. Each time the car shakes I notice the voltage gauge jump toward a higher voltage and the car switches to a fast idle of 1000 rpm. The shaking gets worse and worse but I haven't let it go to see if it will stall as I wanted to get home. Once driving and the rpm's are up over idle speeds the car behaves perfectly normal. So each stoplight I hit or stop for traffic it would idle ok at first then start to shake.
What should I look out for?
Vacuum tree by the master cylinder on the firewall
clean battery connections
IAC
MAF
looking for any suggestions it is my only car and I need it to get to work tomorrow afternoon
IAC
MAF
