massacre
- January 24, 2018
- Massachusetts
- ‘94 Explorer
‘19 Nautilus
Hello,
My 1994 4x4 is having steering problems. I jacked it up on each side and found pass side rotor slightly loose. Removed keeper tightened nut, no more loose.
Drivers side seemed dry, I think that bearing might be bad. I repacked it just because I would need it to get to the store to get new bearings, which I will do.
Seemed slightly better after repack but still same issue.
What happens is, after taking a turn, instead of returning to straight the truck wants to keep turning. You have to correct it to keep it going straight, when correcting the wheel gets stiff for a second. It does it in both directions. There is an audible noise as well.
No play in ball joints that I can see, everything seems tight. It does feel like bad ball joints or steering shaft but I remember checking the shaft when I replaced the steering box and it seemed fine.
There is def high speed vibration as well. Ball joints have no grease fittings and truck has 93k miles on it. I’m not against changing the balljoints but I would want to do everything and that might be a bigger job than I had bargained for. If I can get my Mustang road worthy (waiting on parts) I don’t mind having the Explorer down for a while. But for now it’s all I have. Tie rods and center link do have grease fittings and look to be older Moog parts from the boots. No play that I can see.
P/S pump whines but is brand new and always did it. Turned lock to lock for like 5 minutes Fluid level is fine and new atf. Pump, box and lines are new.
Radius arm bushings I couldn’t see play there but I might be hearing some. The rear suspension is a little noisier than usual too, i’ll check that out.
If the truck doesn’t want to return to center after turning and is stiff when correcting for that, what is the common cause? I’ll replace both wheel bearings and report back. I seem to remember the parts store only having 1 wheel bearing in stock as I had issues before. Once 4 good bearings are in at least I can rule that out. Drivers bearing seemed bad anyways.
Thanks for any help
Thanks for any help
