well the only suspinsion lift available cost 1500- 2000 so unless you want to spend major buscks here is what you can do.
for 2" you can do a torsion twist up front and war-153 shackles in the back. the tt is free and the shackles cost around 60 bucks, and you have to get an alinment after that.
your other option is a body lift, they come in 2" and 3" styles. they run 100 -140 bucks.
do some searching around the site and you will find instructions on how to do all this and lots of pics.
Welcome, and good luck, and dont forget to post a pic of your truck!!!
Pending this is 2wd you can do a 3" suspension lift, courtesy of procomp via spindles and AAL, for around 650. Then for 2 more inches a torsion twist for the front and a shackle for the rear (50)....so you're looking at 5" of lift for 700 bucks.....you would then of course have to get an alignment......good luck.
