Tedybear
- March 7, 2016
- Fulton, NY
- 1995 Ford Explorer
I swear everyone is going to get sick of hearing from me eventually.
Planning on the maintenance, but wanted to get some feedback on this one issue:
Going down the road the "Auto 4wd" is supposed to be able to be engaged "on the fly". (not the 4wd low range. I've not tempted fate with that one yet)
Well, I'm not much into flies. I come to a stop and switch on the auto 4wd. The transfer case does it's thing. The truck moves forward and is riding very rough, almost like I'm driving a flippen Sherman Tank! Lots of shuddering and noises like the front end is ready to blow apart.
I can put it back into 2wd mode and the ol' girl settles down and goes down the road fairly smooth and with out issue.
I did note the front diff was a hair low on fluid. It's been topped off. (I'll likely drain and refill that as well once I manage to find something useful to suck the old fluid out with)
Here's my concerns, and if someone could tell me if they could be related?
Speed sensor is inop below 2,000 RPM. (No one seems to have access to the wiring information. I'm fairly sure it's a bad wire...)
I'm running 235 75 15 on the rear. 235 70 15's on the front axle. (All I have for the moment until I can afford to put new tires all around this on the stock wheels)
Could any of those two issues create my "Rumble-Shake-rattle-n' roll"?? It feels like the front end is shaking itself apart--until I go back into 2wd mode. Then the ol' girl does okay.
I checked the U-Joints on the front drive shaft. Seem to be fine without any play or clunks.
Next few days I'll be nipping up another set of jack stands so I can get all 4 wheels off the ground and seeing if I can recreate those issues/shudders/noise. Also need to locate what I'm sure is a bad wire to the speed sensor, just wish I knew where those two wires are plugged into. (Yeah I know where they wind up on the end of the transfer case....It's the other end I need help with)
Any ideas are welcome!
Thanks!! I'll check for responses tomorrow morning.
S-
S-
