HarryN
- October 2, 2021
- Pleasanton, CA
- 1995 4Dr.
Hi - my mini van was demolished in a crash a few months ago.
If you are curious, there is a photo of the remains in my introduction thread.
My fantastic son in law has located an explorer from within the extended family and is doing some general fix up up for me. Have not seen the vehicle yet except for some photos as it is a few hours away.
It will be my first experience with actually owning a Ford, even though I have worked on their vans and driven plenty of Ford cars via business rentals.
This thread is mostly just to help me keep track of stuff related to the vehicle. No great insights - just me learning and minor tinkering.
_________________-
General specs that I know so far:
- 1995
- 4 door
- Explorer XL
- Control trac 4wd
- Seems to be in remarkably good condition (at least the interior)
General plans / assumptions:
- Probably will need some front end suspension work on the usual joint locations. (assumption)
- Brakes looked ok to him
- Tires looked ok to him
- Since my back is kind of sensitive to shock right now, I might look at ways to reduce the effect of "shock" going through the vehicle to my back as it goes over pot holes and bumps.
- No plans to off road or anything like that.
- Might drive to the mountains / road snow as my back gets better.
Edit - add changing the thermostat and checking coolant system to the list.
I build conversion van electrical systems, so will likely put some solar panels and a power system into this one like I had in my mini van.
- Roof looks narrower than the mini van, but hopefully can get the old panels mounted on the explorer. If not will pick up some shorter ones.
- Debating on building up an "over the wheel well" type power system or pulling out the rear passenger side seat and putting it there.
On the minivan - I put the system into the seat location.
_____________
In the photo that my SIL sent, there appears to be a steel bar just behind the rear wheel well that goes cross wise just above floor level and anchors to each side. Not quite sure if that is something from Ford or an after market thing that the original owner installed.
Something for me to think about.
_____________
That is about all that I know at this point other than what I am reading on this forum.
Thanks for all of the information that is posted here.
_________________-
- 1995
- 4 door
- Explorer XL
- Control trac 4wd
_____________
_____________
