1995 ford explorer eddie b. | Ford Explorer Forums - Serious Explorations
brewsterman
1995 ford explorer edie
Good day ford enth.... I have a 1995 ford explorer eddie bauer ,which i use daily for work,i am also fixing it as i go along,currently i want to fix the check gauge light that is constantly on,also the oil meter pressure gauge seems to be broken,can i fix these problems as a do it your selfer?
You will need a code scanner to determine what is causing the check engine light to stay on.
Could just be a bad oil pressure sending unit causing the gauge not to work properly. Not too hard to replace.
Welcome to the forum:chug:
you will need a code scanner to determine what is causing the check engine light to stay on.
thanks bro.
