1995 Ford Ranger. | Ford Explorer Forums - Serious Explorations
1995 Ford Ranger.
myranger1
Hello folks, I need some help with a no idle problem on a 4.0 v6. I checked the fuel relay and it is good. The truck starts fine with no miss and then dies. I just swapped out the engine and I was wondering if I crossed the fuel lines would that be an issue. Please help!
Thanks,
Johnny F.
Thanks,
Johnny F.
Things to check would be O2 sensor connections, TPS connections...things of that nature. Is it throwing a code?
..Welcome here..:D
..If you had your location under your name, someone in your area might read this and help you out with a scanner if they saw you were in their area..;)
Does it run fine if you give it slight throttle?
If so, I'd look into the IAC valve maybe not working.
I changed the iac valve and it is idling from 3000 grand to 800, I checked the pressure and it is low. I found a hole in the fuel fill neck and have ordered one. I think it is loosing vacuum in the tank, also found that the line was unhooked to the tank.
Thanks,
Johnny
..Welcome here..:D
I live in Parrottsville Tennessee.
Thanks,
Johnny
