Dave Livesay
- November 7, 2018
- Covington
- 1995 ford ranger xlt
Hi ....new here...Have looked thru threads and can't find anything about my problem (maybe not looking in the right place) My trans stopped moving....pump seems to be working. Dropped the pan and no funny stuff in it so I'm thinking electrical prob. Pulled the valve body and gaskets have no breaks or pieces missing. The truck will move in one gear(Limp mode) and you can get reverse if you rev the engine .O/d light would sometimes flash.. I found several places on the internal solenoid harness where the outer wire insulation has cracked and wire is exposed.Can this be shorting out? Also the truck will pull a hill great in the one gear,no slipping. Wasn't slipping before just happened all of a sudden.....Not an automatic guy so I'm stumped...Any suggestions would be great........Thanks
