Tonight I buttoned everything back together and at first nothing changed except I was getting firmer shifts, I am contributing to the adjustment on the epc ( I only did a 1/4 turn CW on it). I did put my original green epc back into the CVB vb, (which had a red one in it). The 2-3 flare was still there, but not as bad. Still no reverse. I could tell it wanted to go into reverse sometimes, but not every time and I was still getting a 2-4 second delay from feeling the clunk or engagement. So I pulled it back into the shop and check the fluid level (while running). It was about a quart low so I put a quart in. Well, then reverse clunked pretty good and I had a little reverse, getting some major slipping however. I drove around again and the shifting got smoother but still 2-3 flare. I checked the fluid again and it was showing low again, so another quart. This time when I backed it out of the shop, it clunked good again and then spun rocks everywhere (I wasn't expecting a firm reverse engagement). I drove it to the driveway and went back and forth many times. Reverse would sometimes engage firmly and sometimes softly, sometimes slipping slightly and sometimes spinning tires, still getting a 2-4 second delay in engagement. So I pull it back into the shop and check the fluid, while running. I am definitely in the cross hatched area, so I say what the heck put in another quart. I am now showing a quart too much. I back it out the shop and get firm engagement in reverse, drive it around and definitely getting smoother, crisper shifts, but kind of harsh 2-3. I am thinking I need turn the epc back down now. I pull into the drive, getting tired and just go back and forth between all forward gears and back to reverse. I still get some slippage and delayed reverse, but every time if I give a little gas, it engages. My question is do I have the correct transmission dip stick? Can someone measure theirs in a 1996 2wd and/or give me a pic or measurements. I am showing fluid about 3/4" above the crosshatched area and get the best shifting I have ever had, though still not perfect. I have half a notion to put in another quart for laughs and giggles. Since I have the remote filter on and drain plug now, its easy to adjust the levels. Anyone with any other thoughts? I didn't look at the side servos, but I still want to sometime.
