Ford used 2 different size differentials in the Aero. 7.5" ring gear or 8.8 ring gear. should be tag under rear cover hole plate with ID size #. also listed on VIN door plate label as code
another cause of rear end shudder on acceleration is loose or worn out rear end pinion shaft bearings. is there any lube seepage around the rear differential front seal where the driveline goes in? if so, will have to be serviced
requries high level DIYer skills, best to have shop replace seal/bearings.
find and repair the shudder problem first, will probably save extra change of lube
Aero differential rear end, driveline to left
seal is part #13
Item Part Number Description
1 4851 Rear Axle Companion Flange
2 4662 Collapsible Spacer
3 4236 Differential Side Gear
4 — Upper Control Arm Boss (Part of 4010)
5 4209 Ring Gear
6 4215 Pinion Gear
7 4067 Differential Bearing Shim
8 4204 Differential Case
9 4221 Differential Bearing
10 4209 Drive Pinion
11 4630 Pinion Bearing
12 4621 Pinion Bearing
13 4676 Pinion Seal
To change lube, block front tires. set rear end on jack stands with rear suspension dropped down for access.
Draining the differential, remove bolts on lower 3/4 of cover, loosen the top bolts and let drain. wipe out bottom of differential housing, check for any metal cuttings in bottom and in lube.
to replace, clean both surfaces well of all old sealer and gasket.
use a sealer such as Permatex "Right Stuff"
Fill hole plug is 3/8" or 1/2" square drive, ratchet works best. use a GL5 rated differential lube 75w90. synthetic is best. Ford spec'd a high grade lube for these. don't have to change as often. use a funnel with a flex spout into hole and hold funnel up toward body pan, pouring lube bottle into funnel, will drain down in
Fill to 1/4" below fill hole.
