pepehuertars
- March 30, 2018
- Santiago
- 1996 Explorer Sport
Im about to start a DIY project: Changing head gaskets in my 90k miles OHV 96 explorer.
Some of the symptoms are:
- Losing coolant
- Some water vapor out of the tail pipe
- Coolant smell when starting the cold engine
- Rough idle when starting for the first time in the day
- Rougher idle when starting after 1+ days of parking.
- Strange new noises when starting cold, like rattle from the lower-back part of the engine bay
Tests already done:
- Putting pressure in the radiator brings more vapor out of the exhaust pipe.
Tests to be done:
- Cylinder compression test: This week
Parts:
- New felpro gasket set (heads, throttle body, etc)
- 16 new Felpro head bolts
- New coil pack wires and spark plugs.
- New coolant to replace after draining the old one.
Tools:
- Big arrange of ratchets, sockets and wrenches.
- Oiler
- Plastic scraper.
- Brake clean
The car had a previous owner who might overheated after a radiator leak, but I'm not 100% sure. If that's the case, heads may be warped and in need of resurface, if its not, could be a cylinder crack but I guess I will not know until the heads are out of the motor.
If you have tips, recommendations or opinions on this, they are very welcome since this will be my biggest mechanic work, I'm not sure if I will deliver, but the chance is better than giving this job to a shop.
One initial question: it is necessary to remove both heads on this v6 if the leak affects the other?
Thank you very much
- Losing coolant
Tests already done:
Tests to be done:
Parts:
Tools:
- Oiler
- Plastic scraper.
- Brake clean
Thank you very much
