DemonRat
- November 5, 2011
- Warrenton, Oregon
- 1996 Ford Explorer 4.0
I recently replaced the headlight switch and the harness pigtail because both were melted together. I got both parts from the local store. I checked the back end of the plug i cut off the harness and made sure I connected the wires back together like the one I cut off. After I got that all done I had nothing. Battery was dead. I charged it and when I went to check my lights nothing worked. I had no headlights when I turned the switch. I had parking lights when I turned them on but no headlights, dash lights and speedometer, or rpm gauge work.. The switch has the blue light so I can see what I turned the knob too. I have checked all my fuses inside cab and engine compartment. When I pull the turn signal towards me I have high beams. When I push it away from me I have nothing. I rechecked my wiring and It is good I even went back to my local store and asked if they had one with the colored wires I could take a picture of and they did. Could this be a relay problem. I'm stumped on this and used my power tester to see if all the connections have made have power to them when its needed. Did I get a bad switch?? Any help is much appreciated as I'm about to go out and shoot it.lol.
