In the evolution of the 4.0L, FORD made production changes from year to year to improve NVH, and efficiency.
What I recommend to you so that you get the best performance and reliability from your car is that when changing
the engine with a different one, is to make sure the replacement engine is of the same, or close as possible to the
year and date production of the engine that you are replacing, this is because of production changes in combustion
chamber, piston dish, compression ratio, among others, require a specific computer calibration. When you install an
engine produced in 94', into a chassis with a PCM production year of 96', chances are the computer calibration is going
to be different, mostly being fuel trims, spark timing, and emission controls. Now, your 94' engine when all hooked up
in your 96'and running, may seem fine and normal, but it wont be, this is because the 96' chassis and PCM still think is it running
with the 96' engine with "fast burn" combustion chamber, now only has the older style chamber and piston dish design that will not only effect emission controls, but fuel mileage, power, and detonation resistance.
Here is some good reading on the 4.0 L:
Exploring the Ford 4.0L Engine: Evolution, Components, and Rebuilding Tips for Rangers, Explorers, and Aerostars. Learn more here!
www.enginebuildermag.com
