I have the same problem with my rear door. Except, the door handle seemed to be "stuck" in the open position...meaning as you pull the latch, it was stuck at 45 degrees. I pulled the door panel off according to the directions I've seen on other websites and was able to pull the door handle off. Couldn't see what was preventing it from "closing". As I applied pressure, the door snapped back into place. But, when I thought I fixed the handle and put it back onto the door, I noticed that as I pulled on the handle, while the spring would still spring the handle back into a closed position, the eye (hole) behind the assembly that the door handle release rod clips onto doesn't move. I would expect that as I pulled on the handle, it would pull on the rod. Is the eye(hole) behind the assembly supposed to react/pull as I pull the handle? I'm assuming 'yes'. Trying to see if I have a problem with the handle or a problem with the rod. Any help would be great! Thanks.
James C.
