eric mentzer
- December 10, 2017
- Pennsylvania
- 1996 XLT 4 door 4wd
greetings, my explorer has been running great since the fuel pump and starter have been put on, in previous thread monthes ago. got approximatly 84k miles on her. Just got inspected and noticed radiator is leaking coolant. I think the timing with the garage was a coincidence and it has just recently gotten warm out in PA. I notice the coolant oozing out the body of the radiator, on mostly passenger side. Resivoir is full to line, replaced cap as a precaution. Hose to holding tank is clear, i purged air through it both ways. As soon as i disconnect hose from plastic resivoir with cold fill line, coolant runs nicely out of resivoir tank. If i pull hose off radiator cap and try to blow back into resivoir, nothing, complete restriction. the hose itself is clear, however i cannot blow back into the overflow tank. is there a check valve or something? like i said it runs out freely with the hose disconnected. No overheating temps or issues other than shes dripping good once heats up. Any suggestions what else to check? I hate to throw stop leak at it if it is indeed an overpressurization situation.
