1996 Ford Explorer AC Compressor O Ring / Seal Size / Source / Part Number
Chris from DE
1996 Ford Explorer XLT
Hello,
I'd replaced the AC hose assembly (and other parts) on my 1996 Ford Explorer XLT. Of all the o rings / seals that came with the parts, plus the ones my buddy had, none were a perfect fit for the compressor o rings.
Does anyone have a source / size for the compressor o rings? There were 2 which came with the hose assembly and they were the correct diameter, but not the correct thickness.
I'd tried finding the part # via searches and also through fordparts.com but no luck.
I am going to try the Santech MT2527 kit in the meantime and will return it if not the correct kit.
The factory ones are leaking and they were also pretty flattened.
Chris from DE
Local dealer had them. Ford part YF2963.
S 1996 Ford Explorer 5.0 overheating A/C & Heater systems - HVAC 0
R 1996 Ford Explorer XLT. A/C & heat issue. A/C & Heater systems - HVAC 3
T 1996 Explorer AC Clicking A/C & Heater systems - HVAC 1
F 1996 - Blows Defroster Only A/C & Heater systems - HVAC 0
C 1996 Explorer XLT with a blend door problem. A/C & Heater systems - HVAC 1
M 1996 XLT with climate control problems. A/C & Heater systems - HVAC 5
J 1996 AC Problem. The compressor continuously cycles. A/C & Heater systems - HVAC 3
B 1996 explorer 4.0 ac all new but only blows 60 out of vents A/C & Heater systems - HVAC 18
R 1996 Exploder 5.0 condenser connection? pics? A/C & Heater systems - HVAC 2
F Replacement of 1998 Ford xlt sohc A/C & Heater systems - HVAC 0
D Help on my 1993 ford ranger XLT A/C & Heater systems - HVAC 3
K 2003 Ford explorer EB AC Compressor issue A/C & Heater systems - HVAC 0
P 2004 Ford Explorer XLS - A/C Clicking on Coldest Setting - Left Side of Console A/C & Heater systems - HVAC 1
O 1992 Ford Explorer XLT Compressor issues A/C & Heater systems - HVAC 5
M 2014 ford explorer limited with rear ac A/C & Heater systems - HVAC 0
M 2009 Ford Ranger - A/C not working A/C & Heater systems - HVAC 1
F 2013 Ford Explore Cooling and Blower issue - HELP A/C & Heater systems - HVAC 1
B 98 Ford Explorer A/C issues A/C & Heater systems - HVAC 1
T 2005 Ford Explorer AC only Coming out one Vent A/C & Heater systems - HVAC 0
D 1998 Ford Expedition Eddie Bauer, NO HEAT~ A/C & Heater systems - HVAC 1
J Ford Explorer 2006 A/C not blowing at front A/C & Heater systems - HVAC 3
D New a/c lines 98 ford explorer 4.0 sohc A/C & Heater systems - HVAC 1
E 02 ford explorer V6 4.0L SOHC A/C & Heater systems - HVAC 2
J 2009 ford ranger son's truck A/C & Heater systems - HVAC 0
4 1999 Ford Explorer Eddie Bauer EATC issues A/C & Heater systems - HVAC 1
J 2000 ford explorer xlt A/C & Heater systems - HVAC 0
T 2006 Ford Ranger A/C A/C & Heater systems - HVAC 0
N 2008 Ford Edge A/C & Heater systems - HVAC 0
J 2006 Ford Explorer. Air is not coming out of the A/C panel vents. A/C & Heater systems - HVAC 4
F 2004 Ford Explorer Restricted AC Airflow A/C & Heater systems - HVAC 2
A I need help finding the 2002 Ford Explorer radio wiring diagram. A/C & Heater systems - HVAC 4
B Adjusting Clutch Gap on the Ford FS10 Compressor A/C & Heater systems - HVAC 3
I 93 Ford Explorer AC issue. A/C & Heater systems - HVAC 4
R 03' Ford Explorer NO heat or AC A/C & Heater systems - HVAC 0
T Ford Explorer Compressor Staying On A/C & Heater systems - HVAC 0
U 94 ford explorer, help A/C & Heater systems - HVAC 1
J 1999 ford explorer - Air vents keep switching A/C & Heater systems - HVAC 1
M 2002 Ford Explorer. Auxiliary blend door problem. A/C & Heater systems - HVAC 2
B 2003 Ford Explorer blend door. A/C & Heater systems - HVAC 2
T 2005 Ford Explorer with defrost issues. A/C & Heater systems - HVAC 8
R 2002 Ford Ranger 4 cyl no heat A/C & Heater systems - HVAC 0
L 2004 Ford Explorer XLT Blend Door Actuator Replacement A/C & Heater systems - HVAC 1
T 2000 ford heater will not work please help A/C & Heater systems - HVAC 5
S 2000 Ford Explorer - Defrost Only A/C & Heater systems - HVAC 3
C 2005 Ford Explorer A/C only blows on high. A/C & Heater systems - HVAC 2
A Ford Ranger A/C doesn't work. A/C & Heater systems - HVAC 3
C 2001 Ford Ranger A/C fan motor is not blowing. A/C & Heater systems - HVAC 1
D I have to replace the A/C compressor on my 91 Ford Explorer. A/C & Heater systems - HVAC 3
F 2002 Ford Explorer Front Passenger side cold/ driver side warm A/C & Heater systems - HVAC 12
A where do i find the orifice tube on 98 Ford Explorer A/C & Heater systems - HVAC 0
Similar threads
