LesB
- July 24, 2020
- Durack
- 1996 Ford Explorer UN
I have a 1996 Ford Explorer UN XLT 4 litre SOHC Wagon, it now has an ABS Module failure rendering the ABS inoperable., but still safe to drive
My car was in the last shipment of turnkey drive on/drive off vehicles to arrive in Australia direct from the USA in March 1996.
It has been a great car with little trouble, apart from a factory engine exchange at 175,000Ks as part of the warranty responsibility to replace engines that had timing chain failure that could render serious unrepairable engine failure. I had mine replaced just after it started to rattle a little causing no harm, but Ford Australia did follow up with a recall and a new designed engine replacement, with that engine now at about 200Ks and no trouble, it is quiet, runs sweet and has plenty of grunt after a crankshaft sensor replacement.
The ABS Module has failed and because my Explorer is an old model now there is no requirement under Australian law to hold factory parts longer than 7 years after a vehicle in released to the market.
Genuine Ford Explorer ABS Modules here are virtually impossible to find, so I have to revert to a second hand one from a Ford Wrecker,
The problem with that is Part Numbers to the relevant Model.
I can purchase a working second hand one, but am reluctant until my question is confirmed.
That leads me to a vexed question to the Forum, are all the Ford Explorer ABS Modules the same for my model range, but with differing Part Numbers for each Model?
Here in Australia my particular Model the UN, ranged from 1993 to 1999.
Any advice from the Forum would be welcome, thanks for the opportunity and your time.
LesB
LesB
