96fordexplorer*
- January 24, 2018
- 1996 Ford Explorer
So I bought a 1996 Ford Explorer XLT 4WD the other day. Horn worked fine but cruise control didn't work at all, which is okay because I never use cruise control. So I took out the cruise control buttons and the wire harness that's there in the steering wheel like wrapped in it. If you google 1996 Ford Explorer cruise control switch then that's what I removed. So I tried to push my horn and no noise. I checked the fuses and the relay, they're okay. The horn worked the day prior so I ruled that out for being a problem. So I set off the alarm and no horn. So I don't know what I did or how to fix it. Should I buy new cruise control buttons and see if that helps? I mean I'm stumped, I didnt remove anything except the buttons. If you google 1996 ford explorer cruise control button replacement and watch that, it's what I did except didn't put new ones in. My airbag light is not on so I am ruling out the clock spring. Any ideas?
