1997 Connector question | Ford Explorer Forums - Serious Explorations
Yetii
Columbus, Ohio
97 xlt
I have the honor of putting my engine back together after someone else took it apart (hack mechanic). Amazingly I think I managed most of it. I suspect I'm missing a part on the passenger side. The drivers side has a flat plastic plate bolted to the side of the valve cover into which a square electrical plug goes. This plug has a u-shaped wire clip that keeps it in place. I have an identical connector with the same wire clip on the passenger side that has no place to plug in to. Any ideas? Im sooooooo close.
Thanks!
Found it. I was waaay off. It was the crank position sensor. I re-routed it and plugged it in.
I believe I only have 1 item left! There is a vacuum hose on the passenger side that I can't find a home for. It is one of 4 that are fed by a larger .25" hose attached to the upper intake manifold. The tube is red and the connector is white and male. Any thoughts?
TIA.
Found an open plug from the vacuum reservoir and plugged it in, we'll see.
