jrogerbeck
- November 13, 2014
- 2011 mustang
I have a 1997 Eddie Bauer explorer with the SOHC engine and Automatic climate control. I have had the control unit rebuilt and done the heater treater repair to the broken blend door.. Its latest trick is as you drive around with the control on MAX AIR it switches between cold air and really hot air coming out of the vents . It runs about 5 minutes of each and doesnt seem to have any pattern. The only thing I haven't replaced is the heater control valve. Not sure if that's the culprit so any advice is appreciated.
