1997 Explorer Drivers door won't unlock | Ford Explorer Forums - Serious Explorations
frankieuk
Hello all,
I have a 1997 ford explorer. My drivers side door will not unlock and as such I cannot open the door.
The key turns fine in the door and unlocks the central locking for all the other doors. I've also tried the central locking from inside the car and the door handles inside and out, but the door still does not unlock.
Any ideas for how I can open the door and / or fix?
Thanks!
Solution found! Turned key as far as it would go and held it. Then thumped around the lock area and eventually freed! Bit of WD40 in lock too. Hopefully all will be fine...
