evadsec
- November 21, 2017
- Dayton, Ohio
- 97' Explorer Sport Trac
I have a 1997 Ford Explorer Sport trac two door 4x4 4.0 SOHC, after I bought it the check engine light came on I took it to a auto parts dealer scan it and 4 codes come back the p0174 (fuel system too lean cylinder bank 2) p1131 (lack of ho2s 11 switching ho2s signal low input), p0133 (ho2s 11 circuit slow response bank 1 sensor 1), P0153 (ho2s 21 bank 2 sensor 1 circuit slow response) also the the truck isn't running right , rough idle it dies at a stop light or a stop sign after a little bit of time or in a McDonald's drive-thru waiting too long it starts to putter out if I give it gas it will stay running. I replaced the PCV valve and the plastic T and the two vaccum hoses that run to the intake, also has a rolling idle sometimes but not all the time like it's searching for its idle position, I cleaned the mass airflow sensor I cleaned the throttle body, I clean the IAC and then I replaced the IAC with
Another one that was better and I also cleaned it, vacuum hose that ran to the PCV valve was caved in that ran to the right side of the intake if you were looking at the engine from the bumper that's why I decided to change PCV valve & its 2 vacuum hoses. And yet it still Dies. I called underneath the check out the O2 sensors the downstreams, and the passenger side Downstream is so loose that I can hand untighten it, I put thread lock on it I've attempted to tighten it down on numerous occasions I can't get it tight down and keeps coming loose again., I'm not sure if the passenger side Downstream will cause a vacuum leak 4 my truck is dying, I left it be for the time being and Focus my attention on the fuel filter which looks like it's never been changed so I picked one up and I'm going to put it on very soon possibly today but it's raining right now. Any suggestions would be much appreciated thank you
Oh and when I got it I also replaced, I put a brand new air filter and put a brand new belt on, and oil change.. and I didn't mention I also to the best of my ability checked all my hoses for vacuum leaks I didn't spray starter fluid and I don't have a fog machine but I inspected my hoses as best as I could without needlessly replacing them except for the PCV valve vacuum hose that goes to the intake that was obvious it was caved in.
