Mark Stanfield
- March 13, 2019
- Markleville, Indiana
- 1997 Ford Ranger XLT 2WD
Hey guys, new to this board
My son and I are wrenching on a 1997 Ranger I-4 5 speed. Tranny won't go into gear; grinds and hard to push shift lever. We have:
Any ideas?
- Replaced clutch, pressure plate, master cyl, slave cyl
- Bought a pre-bled line; master, line and check valve came as a kit. Didn't work. Tried to re-bleed (using Perfection Clutch method)...all seems bled
- Clutch seems to move pressure plate about 3/4 of an inch
- Didn't re-surface the flywheel; no cracks
- Last time we pulled the tranny I noticed a "hot/shiny" spot on the pressure plate and flywheel; not sure why. Checked the clutch disc to see if bent...it is not bent
- Can a warped pressure plate or flywheel cause tranny to grind and not go into gear?
Any ideas?
