1997 V8 Explorer PCM w/harness and transmission transplant in my 1977 351w F150
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Thanks for reminding me, I have a vb out a wrecked 04 v6 mustang I pulled out the yard about a year ago on my shelf somewhere I can use. I also have the drill bits and instructions from my baumann engineering shift kit from years ago I'll use to compare.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
I have not done the "J Mod" yet, but I read the various instructions from sites I found last year. The holes vary based on who's doing it, and the application. The springs were the hardest part to select or find, because of differing opinions on affects, and the applications. I plan to select hole sizes on the low side, since it seems likely going back in to adjust is part of the process, for each application. The 2004 VB will be sized on the less harsh side no doubt, but a great initial starting place.
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
"and the Cobra had the slightly higher lift Cobra cam."
Likely because the Cobra was the only one with factory roller-rocker arms. imp
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Yes, the 94/95 did have roller rockers, 1.7:1 instead of 1.6:1 if I recall correctly.
Years ago, my friend and I helped another friend with his 95 Cobra. The balancer let go and he decided my rebuilt 302 from my first Lincoln was worth the upgrade($1700). We installed my engine that had Edelbrock heads and intake on it, and my friend got the old Cobra engine as partial payment. I hope to borrow the GT40 heads from that to swap onto my 98 engine(to build exhaust manifolds to fit them), and get the Cobra intake for a wrecked 94 GT I have to fix up. We have some parts, but little time to do anything.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Little bit of progress. Hoping to have engine and trans sitting in the frame by the end of the month. Only areas on frame that needs attention is where the body mounts sit. I've also lost the use of my trailer for the next two weeks unless I REALLY need it.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
So made some progress......Got the frame painted, new brakes, new kingpins, 3.50 rear axle rebuilt. Still have to fix the frame where the front body mounts sit and a bunch of little things but the suspension is done. Few issues have arose though.
First is the trans mount: It needs to be moved back 2". Problem is the current mount is right where the frame starts to go up in the back, so it can't just be moved back. Also If I leave it where it is and modify the mount it will be near impossible to get the pan off. A new crossmember will be made out of tube.
Headers: I thought long tubes would be ideal but damn they are a pain to install. They don't make 351w headers and the ones I have are made for the 302. The drivers side fits with some decent hammering to clear the steering box (still only about 1/8" clearance after hammering). The passenger side hits the frame rail and the starter portion on the trans. Even with the cab off the engine has to be lifted to get the passenger header in. They will both "work" with a few dings but will be an absolute pain to service. I'm looking for other options which quite possibly means going to shorties. I've tried some mustang headers (short and long) and a set of explorer FMS headers and none work like I want.
I also broke down and bought the knock off PP 351w mustang swap intake. Seems to fit good and be of decent quality. Couldn't pass up the black Friday price of $285 for the polished upper and lower.
The cab has been in the back of the shop getting rust repair. Floors and cab corners are done, along with some patches in the door jam area. Down to roof repair and to decide how much rust I'll fix on the bed. It's all being patched right with steel, no body filler till the last step to make it purdy.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
I also want to add it appears I got lucky with my pick n pull 96 Explorer 4r70w. I pulled the pan and found a reman valve body and bonded accumulators. The torque converter has a date on it of late 98 so it could if been rebuilt early in life. I has decided against upgrading the trans to the 98+ parts as this trans should be good to go (pulled from a wrecked 96 with 150k). I will upgrade or swap it out later if any issues arise.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Excellent progress, that chassis/frame work is tough and important. That should make the truck last a long time and not need much work in the near future.
delexploder
Greenwood De.
97 ford explorer sport
I really want to see the motor fully dressed
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
It won't be long, maybe another month and it will be all sitting in there. With having 4 kids and a stay at home wifey I haven't got much done this month since Christmas is expensive for me lol. Work work work.
Small update though: Cab is 95% done with metal work, about to move on to coatings on it. I'm trying to figure out the rust in the cowl issue now. I have a few pinholes on either side I need to do something about. Crappy thing is the cowl can't be removed without drilling over 100 spot welds. I'm thinking some epoxy in the small holes and dumping in POR15.
Final deal on the engine and trans mounts are as such: I'm using the stock truck perches with 302 mounts and I've plated the trans crossmember so the explorer trans mount can be used. The factory trans mount was only attached by 1 bolt horizontally though the crossmember. That way with the offset of the explorer mount I only have to move the engine forward about 15/16" for everything to work right. I have also found an aluminum E250 driveshaft that will work perfectly for me once I move the engine.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
These are the next headers I'm going to try. As you see in the pic below the summit long tubes that "everyone uses" is going to melt the steering box. Also with the motor going forward almost an inch they are just not going to work.
Next option is Hedman 88660 which are early 70s mustang 351w swap headers. They look like they will work perfectly if they don't hit the cab floor.
delexploder
Greenwood De.
I have the same issues lol , maybe i can see it up close if we come get that tranny off you , havent got to that project yet , and ive got this sport trac just sitting here waiting to be frankenstined
willzilla
Atoka, TN
2000 XLT AWD
Awesome! Wish I knew how to do all of this kind of stuff, lol.
Need to find somewhere close I can "intern" at for free on the weekends, lol! :D
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Got my headers, they'll work way better than the previous set. They look like the might fit a v8 explorer with a 3" body lift with a few mods possibly. Pics taken with a used set of fms explorer gt40 headers to compare.
delexploder
Greenwood De.
Bump
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Man its been awhile. I took a little break from the truck, bought a house and lost all my free time until now. I literally pulled it out from the corner of my shop last week and got back on it.
Since my last update I've got the engine moved forward just under 1" and transmission crossmember modded to use an explorer mount. I'm still working on getting the long tubes to fit how I like but it's getting there. I've got most of the sheet metal work done that I wanted to also. Hoping to start running fuel lines and wiring soon.
delexploder
Greenwood De.
Can't wait to see more
  • Like
Reactions: imp
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Moving can be fun!!!
Love this project keep it up when you can!
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Here's how she sits at the moment. Even with the engine moved forward the header still barely hits the cab. Have a ton of finish work left and to build the wiring harness.
Centaurus5.0
96'
I like where you're going with this! Nice!
But why you put chinese knockoff intake on classic v8 pickup. Why you no merica??
X 1997 explorer 5.0 Need for Speed! 5
M 1997 ford explorer 5.0L V8 wanna go fast Need for Speed! 5
N 1997 explorer limited AWD 5.0 vs 2002 explorer V6 SOHC 4x4 Need for Speed! 19
O I just got myself a Blue 1997 Ford Explorer XLT 2WD w/ a 4.0L. Need for Speed! 6
M MY 1997 5.0, need preferences Need for Speed! 5
4pointslow Old Explorer vs New, we got a race this year! Need for Speed! 18
4pointslow Drag Racing Supercharged Explorer 2 Need for Speed! 9
J Ford Explorer M90 future build. Need for Speed! 14
D 98 Explorer Sport SOHC Need for Speed! 3
Awon2zip Nitrous 1994 Explorer Need for Speed! 278
O 2000 explorer v6 to 302 swap? Need for Speed! 0
99SportX '99 Explorer LS Swap Finished - Was has anyone done it? Need for Speed! 59
R 03 awd explorer turbo build Need for Speed! 10
Awon2zip Drag Racing my 94 Explorer Need for Speed! 2
T 1969 GTO vs 2013 Explorer SPORT Need for Speed! 3
J Explorer Sport 5.0L Swap Need for Speed! 9
C 2003 ford explorer sport trac 2wd 4.0 v6 to v8 swap??? Need for Speed! 8
L "Dora" the 5.4 swapped Explorer, now Whines Need for Speed! 7
M Axle Gear Ratios? Explorer Street Rod Rebuild Project Need for Speed! 14
T 2013 Explorer SPORT vs. GODZILLA Need for Speed! 2
B 01 explorer sport LS swap Need for Speed! 14
R Explorer Express Supercharger Kit 5.0 V8 Need for Speed! 48
W 1996 Explorer 5.0 & E303 cam - Do I need to upgrade stock springs? Need for Speed! 5
J RIP - Jakee's remote mounted turbo explorer sport Need for Speed! 29
P 2nd gen Explorer V8 headers Need for Speed! 148
A Turbocharging a stock 4.0 SOHC Explorer Need for Speed! 29
J Henson's 2001 Explorer Sport baseline Need for Speed! 69
R Explorer Sport......very odd timing indeed... Need for Speed! 13
J New Explorer Need for Speed! 65
1 Plans have changed....99 explorer 5.0 turbo time! Need for Speed! 17
2000StreetRod Explorer Express Supercharger for SOHC V6? Need for Speed! 15
S Will TMH's fit 2001 Ford Explorer Sport 4.0? Need for Speed! 3
L My sons new 98 Explorer sport Need for Speed! 2
R Pro Street Explorer Need for Speed! 15
R will 5L CAI from Mustang fit Explorer? Need for Speed! 5
V 2000 Explorer Dynotunning Video Need for Speed! 6
V M112 on Explorer Need for Speed! 12
R Explorer V6 engine info Need for Speed! 4
J STS Turbo 01 Explorer sport vs v8 S10 Need for Speed! 35
J STS Turbo 01 Explorer Sport 13.55 @ 101 video Need for Speed! 0
S Beginner looking for some advice about a 94 Ford Explorer. Need for Speed! 4
L Turbo Explorer @ Lowes MotorSpeedway Need for Speed! 20
T 98 Explorer 5.0 More Power Cam ??? Need for Speed! 5
K 2008 ford explorer XLT 4.6l Need for Speed! 2
T turbo explorer new exhaust Need for Speed! 16
1 98 Turbo Explorer sport " UPDATE " Need for Speed! 10
B explorer sport trac super charger Need for Speed! 18
M 02 Explorer Sport VS Lightning, stand a chance? Need for Speed! 16
ebox86 2001 Ford Explorer vs 2000 Chevy POS Blazer Need for Speed! 31
I Powerstroke into an Explorer? Need for Speed! 32
Similar threads
