1997 with 95 ecu?
97 Expy 302
97 Explorer XLT
Working on the engine to get all the smog gear working right and I started wondering if an earlier ecu from an obd 1 explorer would work and would it allow me to cut out a lot of the extra smog gear in my explorer. Any experience or advice? I found the older computers were much cheaper than the 89-93 mustang computers.
Thanks!
J_C
Florence, KY
1998 XLT 4WD 4.0L SOHC
Don't know but wouldn't the cost of a used one at a junk yard be pretty close to the same for either generation?
gmanpaint
It's Always Something!
Staff member
Moderator
MO MO
94 & 95 XLT's
OBD1 is 60 pin, and the connectors are 2 wire.
OBDII is 120 pin and most connectors are 3 wire.
You would have to not only change out all the wire harness, but also some engine parts, some modules, gauge cluster, ignition system, fuel delivery system, ABS/speedo system, and then there is the transmission to deal with.
So I would say no, won't work.
97 Expy 302
97 Explorer XLT
Got it. I was hoping for something easier but it looks like I need to get the stock smog gear replaced and working. Thanks
koda2000
x
I doubt this would work. I've seen ECU differences w/in the same model year. Besides, why go backwards to ODB I even if it would be plug-and-play.
