  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
1998 4 door Explorer
Mike65
Location
In my garage working on one of our vehicles.
Toms River, NJ / Horsepasture, Virginia.
00 Ranger 4x4, 99 Sport.
Congrats. :chug:
donalds
Location
Stem
Nc
1999 ford explorer sohc
I'm keeping up with your YouTube videos
I can't wait to see the rest of the teardown and the fix keep up the good fun:)
4pointslow
Explorer Torture Tester
Gloucester City, NJ
98 2Dr,98 & 04 4dr xlt
This happened last Sunday (9-29-2019).
The transmission started shifting hard and slipping between shifts as I was driving.
After arriving at my destination I shut it off and when I came back to the truck and started it, the idle was around 2,000 RPM's.
GLOCKer
Location
ATL Area
Marietta, GA
1998 Explorer Limited
Check your trans fluid. I'm wondering if the fluid has broken down?
GLOCKer
Location
ATL Area
Marietta, GA
Oh it's also idling low? Sorry I missed that.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
With the fluid full, does it pull evenly and properly with gentle throttle, in reverse also?
If there is a major fluid leak internally, the system will command maximum pressure from the EPC, which will throw the code for that, plus make all shifts harder.
Mine broke a part that ended up in the pan, the code was for the EPC over pressure, and it moved with a lot of slipping in both directions.
donalds
Location
Stem
Nc
Could this be engine related iac tps
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
You could check the TPS voltage, if it's was way off it could affect shifting and idle etc, but I doubt the trans slip feeling being connected to it.
4pointslow
Gloucester City, NJ
Here's the latest on the check engine light.
You wont believe what happened next.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Great, I'm glad it was an easy check and fix.
I have a check engine light on my 95 Crown Vic now, since the weekend. I just received a cheap OBDII scanner today, I hope it is that simple to fix on mine.
4pointslow
Gloucester City, NJ
I wish all our explorer problems were this easy and cheap to fix. LOL
Check out what happened now.
Can you see what is broken?
donalds
Location
Stem
Nc
Time for new leaf springs. This it a great opportunity to upgrade :D
I look forward to your YouTube videos and threads keep it up
Btw. When I saw your green explorer it made me want to supercharge mine ...and I did lol...
4pointslow
Gloucester City, NJ
Well, I installed two new leaf springs. Advance auto even had one in stock.
Did rear shocks too. This was all done back in October.
Flash forward to November and my Motorcraft (plastic) replacement thermostat housing started leaking.
I just replaced it using the Simons Autosports aluminum one, but I used an Austek upper outlet since they make it with the right angle for the 97-98 Explorers.
No leaks now and I'm still driving it with 312,000 miles. LOL
donalds
Location
Stem
Nc
Hell yea
4pointslow
Gloucester City, NJ
Last week I started seeing small coolant puddles under this truck.
When I opened the hood I saw coolant leaking from around the seems of the radiator, and around the internal transmission cooler fitting seems as well.
All on the drivers side of the radiator.
Yesterday, I installed a new radiator from Advance Auto. The radiator was a CARQUEST part and had the Spectre Name on the radiator itself.
The radiator support is rotted out pretty bad and laughed when I saw Advanced auto had one listed on the website right under the radiator and hoses. LOL
With all the other body rot I do not think it is worth it to replace at this time, even though the part was listed for an affordable 139.00.
I have about 313,000 miles on this truck. I don't drive 42 miles to work anymore since I changed jobs last November, so the miles grow slowly now.
Maybe this will be the year I replace this poor truck and let it rest in pieces.
Hacra
Nurmijärvi
1997 5.0 Eddie Bauer
You can get beginner level MIG or TIG welder with that 139$, that truck would be perfect practice piece.
:hammer:
4pointslow
Gloucester City, NJ
It Died!
Was on my way home and almost made it there but all of a sudden the steering felt a little stiff.
As I looked down I saw all the lights on the dash lit up.
I put it in neutral and tried to crank it but it cranked real slow as if fighting compression.
Pulled to the side of the road and called AAA.
Tried to crank it again, and it cranked like there was no compression.
Got it home and it now sounds as if the crankshaft is just free wheeling. I assume one of the timing chains jumped.
Of course this happened after I started removing the engine from the race truck.
I guess this is motivation to get the race truck engine swapped, so I can get this 4 door in the garage and tear it apart.
And the mileage is....
donalds
Location
Stem
Nc
Sounds like fun to see you fix it :popcorn:
4pointslow
Gloucester City, NJ
Fun indeed but I am getting a little scared.
I'm down to 2 vehicles that are drivable, don't want to end up with all 4 broke down at the same time. LOL
Quite a few years ago I had three and they all broke down at the same time. Timing belt(1988 Dodge Caravan), dead battery(1994 Ford Thunderbird), and master cylinder(1988 S10 Blazer). I drove the blazer to get parts for all three and started at them. Finished the last one at like 3:00 am the next morning. Went to my girlfriend's(at the time) house later that morning and we broke up. And did I mention my TV broke at the same time?
LOL, it was definitely a trial.
I'm feeling much better now. LOL
S 1. Both Differential Oil changes plus Transfer Case, Transmission Oil Service 1998 EXPLORER LIMITED 5.0, 4 door, air suspension, AWD, Stock 1995 - 2001 Explorers 20
R The left rear passenger door on my 1998 Explorer XLT only opens part way. Stock 1995 - 2001 Explorers 1
C 1998 Explorer Door Wiring Stock 1995 - 2001 Explorers 3
P Climate Control Issue 1998 Explorer. Are these symptoms of a blend door/actuator? Stock 1995 - 2001 Explorers 1
G 1998 Explorer inside/driver door latch not working Stock 1995 - 2001 Explorers 1
L 1998 Explorer Sport 2 door Stock 1995 - 2001 Explorers 0
1Aauto How To replace Outside Car Door Handle Ford Explorer 1998-04 1AAuto.com Stock 1995 - 2001 Explorers 0
R I'm looking for a door lock wiring diagram for a 1998 Explorer XLT. Stock 1995 - 2001 Explorers 4
R Door Mechanism On 1998 Explorer Stock 1995 - 2001 Explorers 3
R door lock wiring digram 1998 expolrer xlt. Stock 1995 - 2001 Explorers 3
R door lock wiring digram 1998 expolrer xlt. Stock 1995 - 2001 Explorers 0
P Disabling Automatic Door Locks 1998 XLT Stock 1995 - 2001 Explorers 3
B My 1998 Mountaineer has door lock & handle issues. Stock 1995 - 2001 Explorers 3
O 1998 Mercury Mountaineer Power Door Lock Issue - Have a mind of their own Stock 1995 - 2001 Explorers 14
S Is the GEM and CTM one module or two on 1998 SOHC 4WD auto Stock 1995 - 2001 Explorers 11
S Is a 1998 Explorer Limited 5.0 Full Time 4WD w/transfer case towable behind an RV with all four wheels down? Stock 1995 - 2001 Explorers 1
W Problem with ABS on 1998 Ford explorer XLT Stock 1995 - 2001 Explorers 2
R 1998 Eddie Bauer limited CV axel &frustrated Stock 1995 - 2001 Explorers 4
K Convert My 1998 4.0 AWD manual transmission Ford Explorer to 2 wheel rear drive Stock 1995 - 2001 Explorers 1
F 1998 maintenance and general questions Stock 1995 - 2001 Explorers 6
F Motorcraft ac component PNs 1998 XLT SOHC Stock 1995 - 2001 Explorers 1
O 1998 Explorer XLT: ABS ISSUE / DROVE W/ PARKING BRAKE Stock 1995 - 2001 Explorers 26
F What items need to be done before long trip - 1998 Ford Explorer XLT w/ 215,000 miles Stock 1995 - 2001 Explorers 5
B 1998 EB SOHC fuel economy change Stock 1995 - 2001 Explorers 4
D 1998 V6 random dead issue Stock 1995 - 2001 Explorers 6
C 1998 Ford Explorer 4L OHV engine freeze plug trouble Stock 1995 - 2001 Explorers 13
F will a 1998 5.0 AWD explorer transmission interchange with 1997 5.0 AWD explorer trans? Stock 1995 - 2001 Explorers 2
B 1998 5.0 EXPLORER WIRING TO COMPUTER Stock 1995 - 2001 Explorers 1
T 1998 Ford Explorer timing chain Stock 1995 - 2001 Explorers 2
C 1998 Explorer - key stuck in lift gate Stock 1995 - 2001 Explorers 2
C 1998 Ford Explorer XLT P0171 and P0174 codes Stock 1995 - 2001 Explorers 35
N 1998 Can't stop alarm, car won't start, no keyfob Stock 1995 - 2001 Explorers 6
G Solved PATS location for 1998 Explorer XLT AWD Stock 1995 - 2001 Explorers 0
G 1998 explorer goes in reverse but not in drive. Stock 1995 - 2001 Explorers 0
A 1998 Explorer XLT Stock 1995 - 2001 Explorers 5
E 1998 Explorer - Dies when hot Stock 1995 - 2001 Explorers 3
B Noise from alternator area - 1998 4.0 SOHC Stock 1995 - 2001 Explorers 4
R Ac trouble on a 1998 explorer Stock 1995 - 2001 Explorers 1
G 1998 Ford explorer 4.0 sohc vin - E Stock 1995 - 2001 Explorers 3
A Will 5R55E from 2000 4.0 Mounty bolt into 1998 4.0 Explorer? Stock 1995 - 2001 Explorers 4
N 1998 4wd Front Suspension Diagram and Advice Needed Urgently Stock 1995 - 2001 Explorers 7
E A 3rd Explorer? V8 AWD 1998 165k "transmission lines rusted/leaking" Stock 1995 - 2001 Explorers 9
B removal of 1998 Explorer Limited cruise control switch Stock 1995 - 2001 Explorers 5
Mbrooks420 Speedometer flaky 1998 5.0 Stock 1995 - 2001 Explorers 6
S 1998 Explorer sport error code P0340 Stock 1995 - 2001 Explorers 0
B 1998 Explorer Limited mystery plug in armrest console Stock 1995 - 2001 Explorers 4
A Performance issues with my 1998 Explorer. Stock 1995 - 2001 Explorers 15
B 1998 Explorer_shift indicator repair?? Stock 1995 - 2001 Explorers 3
N 1998 xlt 5.0 guess this hose/pipe Stock 1995 - 2001 Explorers 15
B 1998 5.0 problem. Need ideas. Stock 1995 - 2001 Explorers 48
Similar threads
