stevesmustangs
- August 23, 2011
- jerome michigan
- 1998 ford explorer 5.0
I am new to this site i am sorry if i posted this in wrong spot. Anyways i bought a 1998 ford explorer with a 5.0 liter 302 with 80,000 miles for my 17 yearold. My problem is it wont charge the battery. It has a new 130 amp alternator on it and a new battery. I took new alternator and battery to advanced auto to have em tested to make sure they are good, the alt was good he said it should be between 13and17 volts it was at 14, the battery is a 650 cold cranking amp and it registered 695 and good. It hold a charge great but its not being charged from alt. I checked the 30amp fuse in panel under hood, the 5.0 needs the 30amp, it was good, i took 2 ground in front of driver fender off and cleaned em along with the one hooked to the negative cable, i also cleaned the 2 on fire wall. I also have a 4.0 2001 explorer and i had a problem with the negative cable being corroded way down the cable i had to cut insulated stuff off to find that problem. What do you think is the problem with my 5.0 explorer? sorry the message is so long, thanks for your help in advance
