1998 5.0 fuel pressure regulator. Where is it?
1998rollover
Weiser, ID
1998 Mountaineer
Where is the fuel pressure regulator on a 1998 5.0 Mountaineer? How nasty of a job is it to change?
My 02 Sport Trac with 98 Mountaineer drivetrain has suddenly started running real rich, with DTCs indicating both too rich, too lean for both banks and fuel trim out of range.
SoHK_alumni
Tampa, FL
5.0 V8 2002 Ranger
On the '98, the FPR should be at the right rear corner of the fuel rail, just behind, inboard and below the throttle body elbow.
Only two screws and a vacuum line, no big deal. Very changeable in a parking lot as long as the engine is less than scalding hot.
Starting in '99, the FPR go moved into the fuel tank, a much more involved job to replace!
R 1998 3.0 - 5.0 fuel pressure Modified 1995-2001 Explorers 0
1 Too much fuel being injected in 1998 5.0 Modified 1995-2001 Explorers 19
W Please help - Modified Oil Capacity - 1998 Explorer 5.0 AWD - Oil Pan? Oil Capacity? Modified 1995-2001 Explorers 2
M 1998+ ranger front axle into 1995-6 Explorer Modified 1995-2001 Explorers 7
M manual locking hubs on 1995 Ex, 1998 ranger parts? Modified 1995-2001 Explorers 9
F 1998 Fog light on switch??? Modified 1995-2001 Explorers 8
S 1998 explorer with1978/79 d44/d60 build Modified 1995-2001 Explorers 3
redavis460 Another 1998 Explorer Sport V8 Project. . .Completed! Modified 1995-2001 Explorers 94
S Removing Kenwood Stereo from 1998 Explorer Modified 1995-2001 Explorers 2
R 1998 Ford Explorer XLT 5.0L - Discontinued or Obsolete Parts Modified 1995-2001 Explorers 7
K 1998 explorer sas Modified 1995-2001 Explorers 7
K 1998 explorer sas Modified 1995-2001 Explorers 18
fordpickupman 1998 5.0 #mamabearstomper Modified 1995-2001 Explorers 11
B 1998 XLT build :) Modified 1995-2001 Explorers 52
R 1998 Ford Explorer Column Gear Shifter Slack Modified 1995-2001 Explorers 3
D Custom RLC Winch Bumper on 1998 XLT Modified 1995-2001 Explorers 22
shucker1 Rear Sway Bar 1998 XLT Modified 1995-2001 Explorers 1
1 Rear axle swap, 1997 to early 1998? Modified 1995-2001 Explorers 4
S Extended Front Brake Hoses on 1998 Explorer Modified 1995-2001 Explorers 5
Anticitizen1 Converting 1998 Explorer Standard Steering Wheel to Later Radio Wheel Modified 1995-2001 Explorers 7
Explorer GT 1998 Ford Explorer Headlights Upgrade? Modified 1995-2001 Explorers 0
Z 1998 5.0 cylinder head replacement Modified 1995-2001 Explorers 2
Z 1998 4.0 XLT missing front drive shaft Modified 1995-2001 Explorers 7
S 1998 XLT Daily Driver Build Modified 1995-2001 Explorers 6
S 1998 Explorer XLT cutting the rear quarters Modified 1995-2001 Explorers 9
redavis460 75mm Accufab throttle bodies, 347's, and 1998 Explorer Sports; an impossible dream? Modified 1995-2001 Explorers 35
S 1998 explorer antenna wont go down Modified 1995-2001 Explorers 2
J Engine oil cooler lines... HELP! 1998 EB 5.0 Modified 1995-2001 Explorers 1
M 1950 Ford F1 Pickup (flatbed) on 5.0L AWD 1998 Explorer Frame and Chasis Modified 1995-2001 Explorers 30
K Upgrading 1998 Explorer 4.0 to 2000 5.0 Issues Modified 1995-2001 Explorers 28
J My 1998 EB 4x4! Modified 1995-2001 Explorers 2
F 1998 Eddie Bauer 4x4 build Modified 1995-2001 Explorers 3
1 Heater pipe removal on 1998 5.0? Modified 1995-2001 Explorers 3
J Header Bolts for 1998 5.0 Modified 1995-2001 Explorers 4
1 Installing a new ABS pump? 1998 Modified 1995-2001 Explorers 0
C Lowering 1998 Explorer Modified 1995-2001 Explorers 2
9 31's on my 1998 Modified 1995-2001 Explorers 6
B 1998 Cloth Seats to 1995 Heated seats help Modified 1995-2001 Explorers 1
J Adding Glasspacks to a 1998 Explorer 4.0 V6 SOHC Modified 1995-2001 Explorers 2
S 1998 Ford Explorer XLT Aftermarket Radio Modified 1995-2001 Explorers 5
M 1998 mercury mountaineer body lift Modified 1995-2001 Explorers 5
C Difference between 1997 and 1998 wire harness Modified 1995-2001 Explorers 13
C 2006 Mustang 4.0 in a 1998 Explorer Limited Modified 1995-2001 Explorers 0
S Slamming a 1998 Limited? Modified 1995-2001 Explorers 15
RyansX HELP! 1998 wont shift out of park Modified 1995-2001 Explorers 3
S Brush Guard for a 1998 explorer 4 door 4x4 Modified 1995-2001 Explorers 7
DirtJunky My 2WD 1998 XLT Project AGAIN (prerunner) Modified 1995-2001 Explorers 57
C 1998 Lift Kit Modified 1995-2001 Explorers 7
M 1998 explorer sohc Modified 1995-2001 Explorers 11
9 1998 5.0 ex aal and war153 shackles Modified 1995-2001 Explorers 27
Similar threads
