jhow1
- July 29, 2016
- north carolina
A friend was driving in the mountains with a carload of people when her friends behind her spotted fluid and smoke from under the car. They pulled off right away and had the car towed home.
The next day I cranked the car, idled it for ten minutes, shifted through all the gears, drove it around the yard, drove it slowly for a half mile down a dirt road (gears change fine). All the time I'm looking for leaks and finding none. Further inspection shows a clear leak pattern from the vent tube back. Everything ahead of the vent tube is bone dry and the fluid pan behind the tube is clean of the grime covering the rest of the underbody. My assumption is that the transmission overheated and boiled fluid from the vent. The fluid smells extremely burnt.
She had the tranny rebuild a little over a year ago and it has been running fine since however she did say it had seemed sluggish lately.
I know a healthy transmission doesn't overheat under normal conditions such as this. I plan on doing a fluid filter change and flow testing the cooler. Anyone else ever have an experience such as this?
