kmacpe
- July 27, 2014
- Wappingrs Falls, NY
- 2003 Ford Explorer Sport
HORN is located on the driver side under the battery tray and fender.
Remove the battery tray and tire well cover to expose the horn. The original horn assembly has to horns (high pitch & low pitch) The horn is operated off 12V relay/fuse ckt. The original blue wire takes 12V from the relay to the horn. When the horn switch (under the air bag) in the steering wheel is pressed, it connects the gnd to energize the relay and 12V is then applied to the horn.
In my 1998 Explorer (Limited edition), both horns were bad and the blue wire connection was open (8M Ohms) from the relay terminal (relay 7 in the fuse box) to the horn connector. When the horn switch was depressed, 6V was at the horn connector. Attached a new wire directly from the horn relay terminal to the new horn connector. Add a gnd wire from the horn to the car chassis.
When mounting the new horn, do not attach the horn directly to the car body. This would muffle the horn. Use the bar supplied with the new horn to mount the new horn to car body.
