1998 explorer overheating | Ford Explorer Forums - Serious Explorations
donmiller5
san francisco, Ca
1998 explorer
Code:
I have replaced the radiator, thermostat and hoses. after about 20 miles of driving it still over heats, if I turn on the heater it goes back down. I checked and replaced the oil so I do not believe its a head gasket or cracked block. Any insight would be deeply appreciated. Thanks, Don
Which engine don? Also I hear a lot on here about air pockets following cooling system work, and a certain fill and or burping procedure. Also you may want to peek in the rad and see if you have circulation by the water pump.
