ProcrastiNate
- October 10, 2015
- 1998 Ford Explorer
Lets date this all the way back to lets say Dec 2014. (Todays date is 10-10-2015). Drove the 1998 Ford Explorer 5.0L AWD for roughly an hour then shut it off at a gas station. When we went to leave gas station vehicle wouldn't start. Engine would crank fine, and turn over but felt more like it was running on 4 cyl, low idle, shakey, spit, sputter, die. After about 45 mins, starts up fine no problem. (This was the beginning of the nightmare). This cycle repeats itself for a few days, where if you drive it for 30mins+ and turn it off, it would not start back up for roughly 45 mins.
We then decided it would be best to change spark plugs, wires, and battery. 1 week later, vehicle dies and refuses to start. We tow it to the house and replace fuel filter. Walahh!!! it runs fine for the most part of the winter. (live in Montana, the winters here get cold).
Here comes spring/summer times. Issue starts back up where it left off with 1 minor difference. Drive vehicle for 30mins+ and turn it off. Start back up moments to a few minutes later and drive as little as a couple mins. If we turn it off it won't start again for 45mins. Will still crank, turn over, spit, sputter, die.
Replaced EEC relay, and the incident only happens 1 more time then runs fine for probably next 4 months with not so much as even a hiccup.
4 weeks ago same problem starts again. This time the problem only happens a few times. Once one day, and the next day 2 times. We drive it to AutoZone to get codes pulled. Popped the hood and noticed the EGR tube is completely sheered in half (old age, and heat, vibration, etc...) Go into AutoZone and buy EGR tube and EGR valve gasket, and Purchased a Fuel Pump. EGR tube turned out to be a livid pain to get off so we decided to hold off on replacing it till we get fuel pump replaced. Replace the fuel pump and Walahh!!! Vehicle starts right up without a hiccup. Runs great for a couple weeks.
Now one day drive it to work and noticed when taking a turn and hitting the gas directly afterwards it has a complete loss of power, but then catches right back up and drives. After work drive it home and it dies 4-5 times. As soon as it dies, turn the key and vehicle fires right back up. But when you take a turn or hit the brake then hit the gas, total loss of power then vehicle dies.
Next day vehicle won't run for longer then 50 seconds on first cold start. Each additional start less and less time before it losses idles, bogs down and dies. We took off EGR tube last night and cleaned EGR valve with Carb and Choke Cleaner. EGR valve seems to operate fine. Replaced gasket and put all the new stuff on. Vehicle still continues same issue.
Went and got a Fuel Pressure test (which is hard to test when it won't stay running for more then 20-30 seconds now from initial cold start, and die in less to no time after each additional start). Fuel test pressure gauge reads 10psi on first start, and little as 2psi on each additional start.
We are looking into possibly replacing the 02 sensor under the vehicle thats connected onto one of the exhaust lines, and possibly the dpmfe(throttle postionsing sensor) by the egr valve. we are beyond frustrated and would really love some input here. thanks for reading and hope someone will take some time to reply with light at the end of the tunnel. and hopefully replace my hairs ive ripped out. lol!!!!!!
Tired of buying part after part and would like to narrow this down more. Have Fuel Pressure Regulator on order but would like to see if anyone else has or had any similar issues and too of what extent their resolution was.
Thank You in advance. Any information is very much appreciated at this frustrating state. Would like to fix this before winter starts back up on us.
Parts replaced since Dec 2014:
Fuel Filter x2 (replaced it a second time couple days before replacing fuel pump)
Spark Plugs (AutoLite Napa)
Spark Plug Wires (AutoLite Napa)
EEC Relay (Napa Auto Parts)
Fuel Pump Relay (actually just swapped it with anohter, and swapped back, no difference)
Fuel Pump (Precision Fuel Pumps) $200
EGR tube
EGR Valve Gasket
EGR tube
EGR Valve Gasket
