Nate Tidwell
- February 1, 2017
- Marianna, FL
- 1998 Explorer Sport
I've recently acquired a Light Blue 1998 Sport 2wd, automatic, with the 4L OHV for $500. It's has well about 240k on the dash (still about 50k under my daily driver).
Since it's not my primary transportation, I have time to do what I need/want to with it. I worked on it a little bit for the previous owner. Plugs and wires, have less than 1000 miles on them.
I plan to keep the OHV, not swapping, unless I find a really good deal on a 302+trans. I also know that I will replace the fuel filter as I have no clue when or if it's been changed. I might clean the injectors (while removed, that that in tank crap), and will do pcv valve.
Mechanical issues that I know about:
1. Idle at over 1k, whistle from front of intake manifold (vacuum leak)
Should I just do the intake gaskets, or re-gasket the engine entirely?
2. Transmission shudder after about 45mph.
I haven't even looked at the transmission dipstick.
Low fluid can mess up the clutches and contaminate stuff, block passages in the valve body, etc, I know. Should I just do a filter change, maybe torque converter? Or should I just yank it and rebuild it?
Cosmetic issues: dent in passenger door. Roof or seal leak in cargo area. Driver seat motor and padding suck. Obviously, I'll fix the leak, and get the seat situated. Not sure if I care about the large dent in the door, it still works as it should. Considering on going to the JY to find a sunroof, where I'll probably get seats, unless I steal my father's out his mustang.
What do you think?
What do you think?
