1998 Sport D-44 SAS Complete!!! | Page 6 | Ford Explorer - Ford Ranger Forums - Serious Explorations
I wanted to wait till the truck was done b4 posting here, but here I am, the truck is done.... FINALLY.
The gears and locker are in, and the new driveshaft is in, and it works great, I had it out on the highway and it seems to get a better ride at higher speeds..... Good thing....
Specs:
D44 Front axle from a 84 Grand Waggy wide-trac
4:10 Gear ratio Locked
Warn Manual hubs
Leaf spring suspension
Rancho 5000 shocks all around
94 X steering box
Tom Woods custom front driveshaft
Woodring driveshafts custom rear driveshaft
rear SOA and 3" blocks
Modified Tranny Crossmember (to allow driveshaft to fit)
all the rest of the SAS is custom fabricated
fury
austin,tx
99 ford explorer sport
hey lizardtrac i was wondering if you had any pics of where you mounted your steering box
thanks
Skunk
2/1974-4/2015 RIP
Elite In Memoriam
Freeland, PA
98 SAS X, 94 3000GT VR-4
crap.. pics of steering.... next on my list....
Just got done with the manual t-case swap...
Rx4phun
USA
1998 XLT SOHC
i know you probably posted this before but what are 20 or so switches for? and I am surprised your interior is so clean with all the wheeling you do. Good job
Bigcheck1
Marlton, NJ
2004 Nissan Xterra
i posted this in the other thread too. what perches did you use for the SOA conversion.. i need to know what to ask for at A&A tomorrow.
thanks
John_Rock
Elite In Memoriam
Houston, TX
2001 Sexy Sport Trac 4x4
thanks
I bought generic perches from a local 4x4 shop and grinded on them to fit the axle tube. I payed $12 for the pair. But if you wanna go spend $45 plus shipping for some that say they are for the 8.8 off a website, then go right ahead. :D
Yomie
Biloxi, MS
06 Toyota
Originally posted by Johnstone
I bought generic perches from a local 4x4 shop and grinded on them to fit the axle tube. I payed $12 for the pair. :D
I did the same thing.
Bigcheck1
Marlton, NJ
2004 Nissan Xterra
then thats what i'm gonna do
Skunk
2/1974-4/2015 RIP
Elite In Memoriam
Freeland, PA
I just went to a&a and asked for 2" leaf spring pirches... they gave me the correct ones, and they are pretty beafy too.. $20
hardazz04
Arlington Tx
97 explorer sport
hey lizard ... do ya still got your old shift motor of the auto t case if so ill take it off your hands.....
thanks
Skunk
2/1974-4/2015 RIP
Elite In Memoriam
Freeland, PA
thanks
yeah.. actually I have 2 shift motors and one good 4405, and one beat on 4405
hardazz04
Arlington Tx
97 explorer sport
how much u want for it? the good one that is...
Skunk
2/1974-4/2015 RIP
Elite In Memoriam
Freeland, PA
the whole 4405 w/shift motor, or just the shift motor, both shift motors were tested and work fine.
Skunk
2/1974-4/2015 RIP
Elite In Memoriam
Freeland, PA
heres updated pics of the t-case shifter...
cdsl227
Brooklyn, NY
2001 Explorer XLT
Now that's pretty...where'd you get that?
Skunk
2/1974-4/2015 RIP
Elite In Memoriam
Freeland, PA
made it.... had the diamond plate sitting in the garage for over a year now...
cdsl227
Brooklyn, NY
2001 Explorer XLT
Very, very nice touch...like the Ford emblem on it too.
hardazz04
Arlington Tx
97 explorer sport
Well im not sure i might need both the t case and the shift motor.... when i took my old shift motor off i could only turn the t case a little bit manually... does that sound right or does that sound like my t case is locked up? can you give me prices for both?
thanks alot
Skunk
2/1974-4/2015 RIP
Elite In Memoriam
Freeland, PA
Make sure you have the truck in Neutral with the e-brake on when you try to shift the t-case by hand ...you should be able to put a pair of vise grips on the selector and enguage both positions, try turning the input, and front output shafts while trying to enguage it, if it still doesnt go into gear, the t-case may be shot. Which front output shaft do you have on yours? the round cup w/cv joint, or half moon type for cardan joints?
cdsl227
Brooklyn, NY
2001 Explorer XLT
Lizard, I'm assuming the rear brake hose is the same between the XLT and the Sport.
Did you use Stainless Steel Extended Brake lines?
I think I read that somewhere...I may be wrong...
Do you have a Part# for the Rear and who you got it from, I put the Bronco knuckles on the front and have the Bronco tubes I'm going to try and fit to the axle for the front...I need to locate a Stainless line for the rear. What length did you use?
Thanks.
FordLover
Houston, Tx
'02 XLT
Thanks.
This is the same thing I need to know.. What are the gen 2 guys doing for the rear brake hose for SOA.
-Martin
