1999-2001 Explorer/Mountaineer 5.0L exhaust for Ranger swap
Tom Saugey
Little Rock, AR
1999 Mountaineer
New to the forum, I’m swapping a 5.0L into my ‘99 Ranger 4x4 and want the stock downpipe/front converters from a ‘99 to 01 Explorer or Mountaineer. I have new Torque Monster headers and need a starting point to run the new exhaust. I plan to go with 2 high-flow cats, 2 1/2” pipe then 2 into 1 muffler with 2 1/2” or 3” single out the back. Does anyone have the factory Explorer setup in a pile of junk parts. They were stainless and hold up well on a daily driver. I think the tailpipe from a later F150 might work out back. Please contact me if you have any of these parts for sale. Email: tsaugey then 52@comcast.net (broken up to confuse scammers) THANKS!
E 1999 OHV to 2001 SOHC SWAP Modified 1995-2001 Explorers 1
5 1999-2001 grille Modified 1995-2001 Explorers 2
O 2001 Hood and Bumper on a 1999 Sport Modified 1995-2001 Explorers 9
G 1999 Explorer: want to fab a new tank-ish body for it Modified 1995-2001 Explorers 1
@ 1999 Explorer Sport Overlander Modified 1995-2001 Explorers 0
kythri 1999 XLT - Rear Diff Rebuild Time Modified 1995-2001 Explorers 17
D 1996 Ford Explorer with a 1999 Ford Explorer engine Modified 1995-2001 Explorers 2
kythri 1999 XLT - SAS Considerations? Modified 1995-2001 Explorers 8
M 1999 5.0 VSS Question Modified 1995-2001 Explorers 5
T 1999 ranger spark advance Modified 1995-2001 Explorers 9
C 1999 5.0 swap to 67 mustang Modified 1995-2001 Explorers 4
6 1999 explorer cam improvement. What needs to be changed? parts wise Modified 1995-2001 Explorers 6
M 1999 explorer head lights not working. High beam works Modified 1995-2001 Explorers 4
F 1996 4.0 4x4 transmission in a 1999 4.0 4x4 Modified 1995-2001 Explorers 0
P 1999 Mountaineer 5.0 AWD Build Thread Modified 1995-2001 Explorers 42
K 1999 Mountaineer “Miss Fire” without codes. Not your typical question. Modified 1995-2001 Explorers 33
J 1999 Explorer Sport 4.0 SOHC Auto to Manual swap Modified 1995-2001 Explorers 1
J 1999 Explorer Sport Exhaust help Modified 1995-2001 Explorers 0
B 1999 explorer to sport trac conversion/swap. Modified 1995-2001 Explorers 6
C 1999 Ford Explorer 4L V6 SOHC -- Engine & Transmission Swap. Modified 1995-2001 Explorers 1
D 1999 Bauer AWD 3" Body Lift? Modified 1995-2001 Explorers 1
S 1999 Replace seats with 02 Explorer Seats Modified 1995-2001 Explorers 4
E 1999 Mountaineer interchangable with explorer? Modified 1995-2001 Explorers 5
S Will a 2007 brush guard fit a 1999 XLT? Modified 1995-2001 Explorers 2
E 1999 5.0 explorer firewall buggy build Modified 1995-2001 Explorers 12
F 1999 ex sport manual conversion. URGENT Modified 1995-2001 Explorers 6
N Dana 35 IFS 4.56 gears for my 1999 ex advice needed. Modified 1995-2001 Explorers 2
S 1999 XLT SOHC - Water Pump or Thermostat Modified 1995-2001 Explorers 2
M 4x2 and 4x4 1999 explorer engines Modified 1995-2001 Explorers 5
S 1999 Ford Explorer Performance Modified 1995-2001 Explorers 4
B 1999 Sport 5.0 Modified 1995-2001 Explorers 8
R 1999 Ford Explorer Modified 1995-2001 Explorers 0
N 1999 Ford Explorer XLT 4x4 4.0LT UR Rear oil leak from brake assembly or axle shaft Modified 1995-2001 Explorers 9
J 1999 Ford Explorer 4.0 SOHC thermostat housing replacement Modified 1995-2001 Explorers 2
C 1999 explorer sohc torque converter lock up Modified 1995-2001 Explorers 13
J 1999 awd conversion, and modified grill guard Modified 1995-2001 Explorers 20
J 1999 ford explorer rear lift idea need advice Modified 1995-2001 Explorers 8
S 1999 motor swap question W/Picture (99 to 00 4.0 SOHC) Modified 1995-2001 Explorers 3
C Question about a lift in a 1999 ford ranger Modified 1995-2001 Explorers 3
W 1999 Mountaineer Transfer case Problem Modified 1995-2001 Explorers 7
M 1999 Explorer Auto Tranny 3rd-4th Slip and No Reverse Modified 1995-2001 Explorers 2
G 1999 Explorer Modifications Possibly Needed Modified 1995-2001 Explorers 28
J Ford Explorer 1999 4x4 Sport TRAC Modified 1995-2001 Explorers 2
N Steering shaft u-joint? 1994 steering box in a 1999 Modified 1995-2001 Explorers 7
T Amplifier Wiring (HOW TO) 1999 Mercury Mountaineer Modified 1995-2001 Explorers 1
1 Mustang rims on a 1999 Explorer? Modified 1995-2001 Explorers 1
S Windshield washer pump 1999 Ford Explorer Modified 1995-2001 Explorers 1
M 1999 mounty 5.0 cold air intake Modified 1995-2001 Explorers 19
A 1999 Explorer Sport Spacers axels.etc help Modified 1995-2001 Explorers 2
K Bulbs on courtest lights .. 1999 XLT Modified 1995-2001 Explorers 1
Similar threads
