  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
1999 5.0 explorer firewall buggy build
EBEX99
Orlando, Florida
'99 Eddie Bauer 5.0
Ive had the sas project done for over a year now. I finally got a daily driver/tow pig. that means the fun begins on the explorer now that its off the road. I decided to build a firewall buggy. i completely chopped off the body, besides floor pan and firewall. i am using 1 3/4 .120 wall dom and 1 3/4 .188 wall dom for the cage (10 sticks total so far). i built the rear of the cage shorter than the frame on purpose. one day ill 4 or 3 link it so the frame will be cut off back there leaving me with awesome departure angles. didn't want to re do the rear of the cage when that time comes here are some pictures of the build so far.
everything gone
Passenger side slider (.188 wall dom)
A pillars and b pillars bent and tacked
starting 1 of 2 rear hoops
Both rear hoops and stringers
door bars. gonna add more haven't decided how yet
rear c pillar done along with some bracing and top windshield bar done
Starting to tie the top together
Lower windshield bar. my plans were to leave the windshield but things change lol
Drivers side front clip/tube
both sides front clip/tube done, also center stringer on windshield.
measuring for harness bar. like a kid in a candy shop haha
basically done bending. got some triangulation to complete (b pillar and roof) but we pulled the cage to make the process easier.
cage pulled (ignore the front center tube the bend is off compared to the windshield bar, still gotta fix that)
will post more pictures as i go. rig is still a long way from hitting the trails. gotta mount grille, ditch abs pump, mount the radiator and coolers, front stinger and lights, get my seats installed along with 5 point harnesses, redo transmission cross member, wiring, center console and shifters.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Awesome, loving it!
95ModdedX
Washington State
95 explorer Ltd
Incredible fab work, any one who does any fabrication knows the amount of skill, time and dedication this amount of work takes.
Well done!!!!!!!
EBEX99
Orlando, Florida
'99 Eddie Bauer 5.0
a few more updates and pictures
finished up the triangulation in the top section and the b pillar section, primered some
Ended up using rustoleum metallic charcoal paint, to match my steering/radius arms and front springs
Laying the cage back on
Getting the front clip/tubes centered and aligned.
Front end aligned and grille test fitted
good choice on the grille :D
Stinger and winch plate/crossmember done
Ran out of welding gas this weekend. so i decided to load the rig up on my "new" trailer and do a test tow. I did some intake work, tuner, and total tune up but the little 5.2 in my ram is still a turd (time for a ford tow pig lol)
still no welding suplies so i started to clean up under the hood. i cut off most of the under hood wiring harness. ditched all the ac, airbags etc. i retained the factory headlight,running lights and blinker part of the harness so i could make the rig street legal one day. and thats like 10 less switches on a switch panel :thumbsup:
got some flux core :roll: wire to finish up the last 6 welds i needed to get done
getting the last of the slider stringers done
got some support tubes in behind the stinger
still need to move rear axle forward, ditch a leaf or so out of the pack to soften up for all the weight i got rid of. fab rear shock cross member/mounts, fab a battery box, tie down fuel tank, mount seats (just ordered cobreau baja ss in black vinyl/cloth yeet yeet) order 5 pt. harnesses, ditch abs module,and order led lighting etc. getting so close to hitting the trails i cant wait!
rabbit91
Surrey
2000 V8 lifted 33s
subscribing, looks sweet!
quite the bow on the coils or maybe its the photo
EBEX99
Orlando, Florida
'99 Eddie Bauer 5.0
Yes they bow pretty good now with the softer springs i put in. easy fix tho just gotta make new lower coil buckets.
1997XLTRollover
1996 AWD 5.0
This thing is beyond cool. Nice work man thing looks amazing.
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
Wow. While I love my doors/roof/windows... this thing is pretty freaking awesome.
01STrunner
Staff member
Moderator
Greer, SC
2001 SAS'd Sport Trac
Awesome work!
rabbit91
Surrey
2000 V8 lifted 33s
Ahh gotcha, I like the adjustable buckets, did the same for my truck and have bump stops inside there
EBEX99
Orlando, Florida
'99 Eddie Bauer 5.0
more pictures and proggress. my seats came in and the cage is complete(for now)
:usa:
Got the seats and harnesses installed, retained the factory power seat mechanism and added rails for the cobreau seats.
Luckily i found a good trade for my tires. i wanted to get rid of the ssr radials because i dont drive it on the road anymore. traded for a set of tsl bias in 36x12.5x15. physically only 1/2" smaller than the 37x12.5x15 ssr's. :thumbsup:
measuring for rear shocks
EBEX99
Orlando, Florida
'99 Eddie Bauer 5.0
got some 5x7 .063 aluminum sheet for $50.20. i decided to start the top first because there is a call for rain the day its making its maiden voyage with the cage. and plus, gotta count on 50% chance of rain at all times here in Florida.
tabs to mount the aluminum
i used thin foam weather stripping to keep the top quiet, and used black silicon on the driver and passenger side to keep it as dry as possible
top all finished up, came out pretty good. need to add a few more tabs in the front to get the bulge out. good for now though
going to hard-rock park in ocala Florida for the maiden voyage, one of the best and only places to craw/climb/wheel other than flat sand trails.
loaded up ready to wheel :D
Flexing on Stuarts rig. his is a 1st gen sport caged out similar to mine, both out for the first time
creepin
breaking some ujoints at the secret spot around the corner
overall a good first outing. first hill, 20 minutes in i broke the drivers u joint and ripped up a stub. same hill my buddy ben destroyed his cardan rear driveshaft. put us both out for a little but we got back out in no time. plenty of carnage with our group all weekend. nick stripped spider gears in his wj, george ripped his pinion out of the front chunk in a dakota, and erik rolled his un-caged yota down roller coaster hill:roll:. (will post pictures later). sunday morning broke another u joint same side and stuart had fuel pickup issues. time to work the bugs out and plan another trip hopefully in november :usa::usa::usa:
crazyflights
St. Joseph, MO
97 1 ton Jeep
I LOVE IT!! I was going to do something similar but didn't get to it!
I like your design. I will get back to one in the future.
G 1999 Explorer: want to fab a new tank-ish body for it Modified 1995-2001 Explorers 1
@ 1999 Explorer Sport Overlander Modified 1995-2001 Explorers 0
D 1996 Ford Explorer with a 1999 Ford Explorer engine Modified 1995-2001 Explorers 2
6 1999 explorer cam improvement. What needs to be changed? parts wise Modified 1995-2001 Explorers 6
M 1999 explorer head lights not working. High beam works Modified 1995-2001 Explorers 4
T 1999-2001 Explorer/Mountaineer 5.0L exhaust for Ranger swap Modified 1995-2001 Explorers 0
J 1999 Explorer Sport 4.0 SOHC Auto to Manual swap Modified 1995-2001 Explorers 1
J 1999 Explorer Sport Exhaust help Modified 1995-2001 Explorers 0
B 1999 explorer to sport trac conversion/swap. Modified 1995-2001 Explorers 6
C 1999 Ford Explorer 4L V6 SOHC -- Engine & Transmission Swap. Modified 1995-2001 Explorers 1
S 1999 Replace seats with 02 Explorer Seats Modified 1995-2001 Explorers 4
E 1999 Mountaineer interchangable with explorer? Modified 1995-2001 Explorers 5
M 4x2 and 4x4 1999 explorer engines Modified 1995-2001 Explorers 5
S 1999 Ford Explorer Performance Modified 1995-2001 Explorers 4
R 1999 Ford Explorer Modified 1995-2001 Explorers 0
N 1999 Ford Explorer XLT 4x4 4.0LT UR Rear oil leak from brake assembly or axle shaft Modified 1995-2001 Explorers 9
J 1999 Ford Explorer 4.0 SOHC thermostat housing replacement Modified 1995-2001 Explorers 2
C 1999 explorer sohc torque converter lock up Modified 1995-2001 Explorers 13
J 1999 ford explorer rear lift idea need advice Modified 1995-2001 Explorers 8
M 1999 Explorer Auto Tranny 3rd-4th Slip and No Reverse Modified 1995-2001 Explorers 2
G 1999 Explorer Modifications Possibly Needed Modified 1995-2001 Explorers 28
J Ford Explorer 1999 4x4 Sport TRAC Modified 1995-2001 Explorers 2
1 Mustang rims on a 1999 Explorer? Modified 1995-2001 Explorers 1
S Windshield washer pump 1999 Ford Explorer Modified 1995-2001 Explorers 1
A 1999 Explorer Sport Spacers axels.etc help Modified 1995-2001 Explorers 2
K 1999 Explorer Fuse Box Diagram Modified 1995-2001 Explorers 4
K 1999 Explorer XLT Dome Light Size Modified 1995-2001 Explorers 1
N 1999 Ford Explorer Sport 4.0L V6. I want to increase the HP. Modified 1995-2001 Explorers 2
V 1999 power seat swap into a 1996 Explorer. Modified 1995-2001 Explorers 2
I 1999 Explorer Sport Modified 1995-2001 Explorers 3
M 1999 explorer xlt 4.0 sohc Modified 1995-2001 Explorers 0
B 1999 Ford Explorer 3" PA883 lift Modified 1995-2001 Explorers 6
99ex22 98 Explorer bumper on 1999? Modified 1995-2001 Explorers 2
J 1999 explorer sport 4x4 Modified 1995-2001 Explorers 8
L 1999 explorer sport upper ball joints help Modified 1995-2001 Explorers 8
D Should i Lift my 1999 door explorer Modified 1995-2001 Explorers 4
W 1999 explorer engine wiring Modified 1995-2001 Explorers 1
D Lift Kit for 1999 explorer Modified 1995-2001 Explorers 6
B 1999 explorer help Modified 1995-2001 Explorers 5
D What is the firing order on a 1999 Explorer 5.0 engine? Modified 1995-2001 Explorers 3
T help with 1999 2wd Explorer Modified 1995-2001 Explorers 2
kythri 1999 XLT - Rear Diff Rebuild Time Modified 1995-2001 Explorers 17
kythri 1999 XLT - SAS Considerations? Modified 1995-2001 Explorers 8
M 1999 5.0 VSS Question Modified 1995-2001 Explorers 5
T 1999 ranger spark advance Modified 1995-2001 Explorers 9
C 1999 5.0 swap to 67 mustang Modified 1995-2001 Explorers 4
F 1996 4.0 4x4 transmission in a 1999 4.0 4x4 Modified 1995-2001 Explorers 0
P 1999 Mountaineer 5.0 AWD Build Thread Modified 1995-2001 Explorers 42
K 1999 Mountaineer “Miss Fire” without codes. Not your typical question. Modified 1995-2001 Explorers 33
D 1999 Bauer AWD 3" Body Lift? Modified 1995-2001 Explorers 1
Similar threads
