1999 Explorer A/C stops blowing cold when I hit a bump
Drex995
Muenster, Texas
1999, Ford Explorer, V6
Like the title says, the AC will blow Ice cold until I hit a bump. while the fan stays on, it stops blowing cold until I either hit another bump or it seemingly decides to work. Anyone have any experience with this problem? Thanks!
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Sounds like you have a loose / faulty wire, fuse or relay. Push /wiggle on all the connectors, fuses and relays related to the AC system.
4 1999 Ford Explorer Eddie Bauer EATC issues A/C & Heater systems - HVAC 1
G 1999 Explorer XLT with a compressor issue. A/C & Heater systems - HVAC 2
J 1999 ford explorer - Air vents keep switching A/C & Heater systems - HVAC 1
T 1999 Explorer with an A/C electrical problem. A/C & Heater systems - HVAC 2
T 1999 Explorer Ac Compressor Wiring Schematic? A/C & Heater systems - HVAC 2
C 1999 Heater & A/C Blower A/C & Heater systems - HVAC 2
A Explorer 2006 AC compressor clutch engaging and disengaging A/C & Heater systems - HVAC 0
M Rear ac line help 2012 explorer A/C & Heater systems - HVAC 1
N My 2016 Explorer Platinum is overheating and the AC system doesnt work A/C & Heater systems - HVAC 0
S 06 Explorer A/C compressor cooling issue A/C & Heater systems - HVAC 0
K 2003 Ford explorer EB AC Compressor issue A/C & Heater systems - HVAC 0
B 2005 Explorer XLT - No lower heat A/C & Heater systems - HVAC 1
I 1993 Explorer 2 Door Sport 2WD ALL new A/C problems A/C & Heater systems - HVAC 2
B 1995 Explorer A/C & Heater systems - HVAC 2
Conestoga Actual Radiator replacement on 2010 4.0L Explorer A/C & Heater systems - HVAC 1
C 1996 Ford Explorer AC Compressor O Ring / Seal Size / Source / Part Number A/C & Heater systems - HVAC 1
P 2004 Ford Explorer XLS - A/C Clicking on Coldest Setting - Left Side of Console A/C & Heater systems - HVAC 1
O 1992 Ford Explorer XLT Compressor issues A/C & Heater systems - HVAC 5
R 97 explorer 6cyl ac vacumn hose location A/C & Heater systems - HVAC 0
S 1994 Explorer XLT AC leak... A/C & Heater systems - HVAC 2
T 1996 Explorer AC Clicking A/C & Heater systems - HVAC 1
M 2014 ford explorer limited with rear ac A/C & Heater systems - HVAC 0
0 01 explorer blower motor won't turn off?????? A/C & Heater systems - HVAC 0
B 99 Explorer A/C Clutch will not engage A/C & Heater systems - HVAC 3
P 07 explorer, is it the blend door or is it the actuator A/C & Heater systems - HVAC 1
T 2004 Explorer Limited - Replacing HU A/C & Heater systems - HVAC 0
Y 98 explorer won't blow cold air! A/C & Heater systems - HVAC 0
R 08 explorer air conditioner help A/C & Heater systems - HVAC 10
D AC in 2010 Explorer A/C & Heater systems - HVAC 1
G 2005 Explorer AC not working A/C & Heater systems - HVAC 0
S 2001 Explorer AC Problem/Question A/C & Heater systems - HVAC 1
B 98 Ford Explorer A/C issues A/C & Heater systems - HVAC 1
K 01 Explorer Sport A/C & Heater systems - HVAC 0
F HVAC Troubles / 2000 Explorer XLT A/C & Heater systems - HVAC 0
T 2001 Explorer Sport 4.0 SOHC Vents stuck on. A/C & Heater systems - HVAC 1
D 99 Explorer Sport A/C Blowing Hot Air A/C & Heater systems - HVAC 1
S 98 Explorer A/C Clutch problems A/C & Heater systems - HVAC 1
P 2001 EB Explorer A/C Leaks 6Cyl SOHC A/C & Heater systems - HVAC 0
T 2005 Ford Explorer AC only Coming out one Vent A/C & Heater systems - HVAC 0
B Need a blend door cable for 1991 Explorer XLT A/C & Heater systems - HVAC 0
M 04 Explorer no heat A/C & Heater systems - HVAC 1
P 2006 Explorer XLT 4.0 Temp blend door fix ? A/C & Heater systems - HVAC 0
T No heat 1997 Explorer. A/C & Heater systems - HVAC 0
P 02 Explorer - Air/Vent control won't work A/C & Heater systems - HVAC 0
J Ford Explorer 2006 A/C not blowing at front A/C & Heater systems - HVAC 3
D New a/c lines 98 ford explorer 4.0 sohc A/C & Heater systems - HVAC 1
S A/C not cold. 2001 explorer A/C & Heater systems - HVAC 3
D 98 explorer blower stuck on high A/C & Heater systems - HVAC 3
E 02 ford explorer V6 4.0L SOHC A/C & Heater systems - HVAC 2
S 03 Explorer rear A/C mix door stuck? A/C & Heater systems - HVAC 0
Similar threads
