    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
1999 Explorer Alternator Upgrade
Baryngyl
Washington state
1999 Explorer
I ordered a new 200 Amp alternator for my Explorer, I called and gave them the VIN to make sure I got the right one, but am not sure it is the right one once I have it here.
My old Alt has 3 places to connect wires as seen in the photos with 3 wires circled and the new Alt only has a place for 2 wires, what if anything do I do with that wire circled in GREEN?
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Does the new alternator match all three bolt holes on the bracket it sets into? If the bolts don't all line up with the bracket holes, it's definitely the wrong alternator.
There are only two alternators for the 2nd gen Explorers. All OHV V6's use a 3G alternator, while the V8 and SOHC V6 both use a 4G alternator(same one).
The 3G has the main power connector on the back side of it, where does the main power cable go on your old one?
C420sailor
Long Island, NY
98 XLT SOHC, 99 EB 5.0L
Weird. I don’t think my 98 or 99 (SOHC and V8 respectively) have that green wire. Gotta look.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Yeah, I think his engine is the OHV 4.0, thus the 3G alternator. My 99 I bought from a JY'd, and they had already sold the alternator and other parts. They gave me one from another 2nd gen, and it turned out to be the OHV model. I used that one in my 91 later, when it's alternator died.
DILLARD000
Location
Earth
USA
2001 Ford ExST
Older original Alternator (3G?) has a 3rd 1pin connector which is feedback
from the Alternator raw\unrectified AC voltage back into the Alternators voltage regulator.
Newer Alternator (4G?) does not have this external jumper as the feedback circuit is now internal to the Alternator case.
2001 V6~4.0L~SOHC has newer (4G?) Alternator with a large power connection & 3pin control connection, no 3rd 1pin feedback connection.
Hope this helps.
More info at
mic98xlt
West Haven, Ct.
98 XLT
03 Sport
That looks just like the connections on my '05 Sport Trac. I thought that type started in '04 on the SOHC engines. Just FYI if it helps.
DILLARD000
Location
Earth
USA
2001 Ford ExST
Better image of the connection differences 3G or 4G Alternator
Previous thread on this subject
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Well done, pictures help a lot. I also posted in that thread, same issue, the three bolt pattern is wrong between the two types(3G versus 4G).
I would prefer to have the 3G units, they have much more aftermarket support, upgrades, and the main armature is more reliable. When that goes in a 4G, it's almost the same cost to buy a new one. I wish the guts of a 3G would go into the 4G case, but I haven't looked at it at all.
Baryngyl
Washington state
1999 Explorer
Yes, it is the OHV 4.0, thought I had included that in my post.
As far as I can tell by looking it is the same mounting hole setup, I have not taken the old one off yet to try the new one as I need to make sure it will work before I go to all the trouble of taking it off to find out it will not work as this is my transportation to dialysis 3 days a week.
The main power cable is the one circled in BLUE, it is a bit hard to see behind the other cables.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
That 4G won't work for your OHV 4.0, check the distance between the two lower/outside bolts. It's different between both alternators. You should be able to swap it, the 4G is usually a little more expensive.
Baryngyl
Washington state
1999 Explorer
I did a quick check and it looks like the new one the holes are closer together.
Looks like I will have to get them to get me another one that does fit.
Where can I find a 200+ amp Alt that will fit, all I can seem to find are up to 130 amp?
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
There should be more high amp choices for the 3G Explorer alternator. I used to see them on eBay a lot, when I was hunting the 4G models. I've seen those run up to 300amps, 200 should be no trouble to find. Be careful on the brands you see, some are a lower quality. DB Electronics is a bad brand I ran into.
RickOTR
97 Sport 4X4
Here's a good source of info on alternators with dimensions.
