Arissett
- September 27, 2022
- Piscataway, New Jersey
- 1999, Explorer, XLT
So basically the door from the outside will not open by itself. The only way to open the door is to use both the inside and outside handles at the same time. Also if you pull the inside handle with all of your force a couple times the door will eventually open. A weird issue with the door is the truck itself doesn’t even recognize when the door is open. Lastly I’ve had the panel apart many times I took apart the other rear door to inspect anything that looked different and everything looked the same.
