1999 Explorer V8, OBDII Code P1451, Canister Vent Solenoid, FUSE #13 Blows | Ford Explorer - Ford Ranger Forums - Serious Explorations
steve_carolina
Charlotte, NC
Explorer 1999 V8 5.0 XLT
Hello Everyone, Glad to have this Ford Forum and Community available.
Hope someone out there can give me some guidance and possibly interpret this data from my scanner. It seems to me that if fuse 13 blows (in the fuse box under the hood) and controls the Canister Vent Solenoid (located above the spare tire), and the freeze frame data in fact points to that then would that be the problem?
I have a 1999 Ford Explorer V8 5.0 AWD.
Check Engine light is on. There are eleven different codes.
P1747 Electronic Pressure Control (EPC) Solenoid
P0750 Shift Solenoid A
P0755 Shift Solenoid B
P0743 Torque Converter Clutch Electrical
P1507 Idle Air Control
P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction
P0135 O2 Sensor Heater Circuit Bank 1 Sensor 1
P0141 O2 Sensor Heater Circuit Bank 1 Sensor 2
P0155 O2 Sensor Heater Circuit Bank 2 Sensor 1
P0161 O2 Sensor Heater Circuit Bank 2 Sensor 2
P1409 EGR Vacuum Regulator Solenoid Circuit
Freeze Frame data is for code P1451 Canister Vent Solenoid
FUELSYS1 CL
FUEL SYS 2 N/A
LOAD_PCT(%) 26.7
ETC(F) 192
SHRTFT1(%) -1.6
LONGFT1(%) -2.3
SHRTFT2(%) 0.8
LONGFT2(%) -1.6
RPM(min) 4139
VSS(mph) 58
This all happened July 27. I stopped for gas in Gastonia after a very humid rainy day and I believe there was water in the gas. I drove for about three minutes and everything went haywire. No acceleration, sputtering...
I changed the fuel filter and cleaned out all the bad gas.
NOW here is the other thing...... under the hood in the fuse box...
fuse #13 (15 amp) controls
Heated Oxygen Sensor\
EVR Solenoid
Camshaft Position (CMP) Sensor
Well I checked and sure enough fuse #13 was blown out.
I replaced it with another 15amp fuse and immediately it was running perfect and back to normal
However...after five minutes it blew out. I tried a couple more and they blew out also.
This info leads me to believe that there is a short in the Canister Vent Solenoid which is located above the spare tire underneath. Would this solenoid cause all the other systems to fall?
Based on this information have you had experience with this type of problem?
I'm trying to save money and not go the the Ford Dealer.
Thank you so much.
Stephen
I havnt heard of this issue, but if you are willing to try, here so what I would do.
Once the fuse blows you see codes for everything to do with thatvfuse, so try unplugging 1 area at a time and see if you can stop that fuse from blowing.
Unplug the wiring going to that canister, replace fuse, and see if that fuse blows. If it doesn't, you were dead onin your diagnosis. If it does blow again, try unplugging your o2 heater cct, etc.
I've heard of guys with o2 heater cct issues, but not quite what you are describing.
O2 sensor heater wire?
I would suspect that one of the O2 sensor heater wires is shorted to ground. Other members have found that one of the wires can lay against an exhaust pipe and eventually the insulation burns off. I suggest checking the LB/OG wires that go the O2 sensors.
