bhmayor
- November 17, 2015
- 2015 Ford (FPIU)
Ford experts,
I was driving my 175K mile 1999 Ford Explorer on the highway, well over 50 MPH and the O/D light started to flash (I had not pressed the O/D button on the end of the shifter). I pulled over, shut off the engine for 5 minutes, restarted the truck and drove on the street for a little while (wherein the O/D light remained off). Then, whence I returned to the highway and got it up over 45-50MPH the O/D light came back on again.
The car goes into reverse just fine (if that matters) and seems to drive fine on the street locally, only when I drive on the highway for more than a few miles does this issue instantiate itself.
The MIL/check engine light is off and I own a CENTECH code reader and didn't see any stored or pending codes on the truck (I'd have to check, but I think the CENTECH is Harbor Freight model 60694). It seems the code reader (from the online manual) can read transmission codes (though I am not entirely sure).
Can anyone give me any idea of what it might be?
I tried to do some research myself (I am NOT a mechanic, nor do I play one on TV) and read about bad 3rd gears, TCC solenoid valves, valve cover gaskets, etc... but there seem to be the same descriptions and a multitude of solutions (with no specific way described to work in pursuance of ascertaining which solution might be most applicable to my situation).
I recently replaced a fuel pump on the truck (with a friend's help) and just want to know if it is something I might be able to repair myself or if I need a new transmission or what. I am willing to attempt repairs that are not too difficult.
Also, how can I determine if I have this 5R??? transmission or not or which 5R??? one I have exactly?
Thanks in advance!
Thanks in advance!
