mountaineer99
- August 27, 2007
I have a 1999 mountaineer with 4.0l v6 the problem that I am having is that the engine run but if I give it any throttle it wants to die out. If I pump the gas pedal I can get it to reach 3000 rpm. If I take my foot off the gas it seems to idle. THe truck was running fine and this problem occurred with no warning.
I replaced the spark plugs and wires first and it made no difference. I then took the coil pack off and checked the resistance and it checked out good. I checked the throttle position sensor and it checked good but I replaced it anyway. I replaced the gas filter. I thought it was the fuel pressure regulator which is part of the fuel pump assembly so I replaced the fuel pump.
I still have the same problem.
Could I have a bad fuel injector?
What about the electronic control module?
I do not have engine light on. I did have a engine light on several months ago which was a vacuum leak I believe the code was p0445 but the light went off when I replaced the gas cap.
I out of suggestions I do not know what to try to replace next.
