1999 Ranger 3.0 FF Adding a Tachometer
allmyEXes
Location
Lickskillet
No. Alabama USA
1997 Blue Ex 4.0 SOHC
Callsign
KAGG 3611 (CB)
My very base model Ranger didn't come with a tachometer either. You would think that as cheap as it would be to put power windows, cruise control and tachometer that all of these trucks would have it.
I want to add a tachometer. If I come up with a speedometer/tach assembly is it as simple as 'plug and play'? Is the wire/wiring already there in the connector?
allmyEXes
Location
Lickskillet
No. Alabama USA
Callsign
KAGG 3611 (CB)
I think that I found some info...
allmyEXes
Location
Lickskillet
No. Alabama USA
Callsign
KAGG 3611 (CB)
So I found out there is a tach wire in the instrument wiring connector. If I wanted to just add a stand alone tach, then the 3rd wire that I think is green would tap in to the tach wire. Does anyone know what color the tach wire is?
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
I believe you could add in a factory one? Aren’t the clusters modular, and the individual gauges can be removed?
allmyEXes
Location
Lickskillet
No. Alabama USA
Callsign
KAGG 3611 (CB)
I might could swap out within the cluster however I did see a video where someone swapped the whole cluster assembly. CTTOI, (Come To Think Of It) My 1997 Merc Mountaineer cluster might swap out with it. I know that is a couple of years older but it is the same overall dash design. My old MM is for parts now.
Edited at 12:20 p.m. One is pre pats and one is pats. I wouldn't think that the instruments would have to be from a pats equipped vehicle.
